MOre new Mods for my L
Old Feb 1, 2004 | 02:02 PM
LatemodelRacer2's Avatar
I figuered it was time for fans on the intercooler and a 160 thermostat not sure if it will much gains in raw power but it should help on my truck since it is a srteet/stoplight warrior with very rare track visits. I also blocked off my EGR.
I got some new tires last week and i had begun to forget what it was like to have enougth tread to pick up rocks in a gravel parking lot. As always heres some pics.
Old Feb 1, 2004 | 02:10 PM
stock on right 160 on left
Old Feb 1, 2004 | 02:12 PM
double post
Old Feb 1, 2004 | 02:14 PM
Big Man's Avatar
Sweet! That should help lower the charge temps some.
Old Feb 1, 2004 | 02:22 PM
LTNBOLT's Avatar
You need a stat that is like your stock one. That spring loaded washer on the end blocks off a bypass when the stat opens up. Blocking off the bypass forces more coolant to the back of the block for even cooling.
I know this because I asked questions about the washer on the end of the stat a couple of years ago. I was going to use the regular style like you have until I found this out.
Old Feb 1, 2004 | 02:26 PM
LTNBOLT
I guess it is back to the drawing boards. Two local guys have them in there L's thats where i got the part number to get this one.
Old Feb 1, 2004 | 02:27 PM
fordmech00's Avatar
what does blocking off the egr do and where do u block it off at?
Old Feb 1, 2004 | 03:15 PM
soap's Avatar
Well thats a bit off topic..............
--Joe
Old Feb 1, 2004 | 08:30 PM
QWIK 150's Avatar
Where did you get your IC fans?
Old Feb 1, 2004 | 09:49 PM
lightning5.4's Avatar
wrong T-Stat
the washer and spring on the bottom of the factory stat does close off the internal coolant by-pass when the stat opens. Without the by-pass closed off after warm-up the engine can (and will) run hot because some of the coolant will by-pass the radiator and keep going round and round inside the engine heating up more each time around. This usually would happen more at idle or at low speeds
Old Feb 1, 2004 | 10:39 PM
I guess ill run her till she blows and then its built motor time
