OK..So When does the Intercooler pump run
Old Jan 30, 2004 | 10:41 PM
Twisted99's Avatar
@ what temp or parameters should it be churning?
Mine was not and I need a little info..
thanks for your help...
Old Jan 30, 2004 | 10:45 PM
LightningTuner's Avatar
It turns on once the IAT2 sensor sees 60 degrees. If it's real cold out, and you're not into the boost much, it'll take a while to come on.
Old Jan 31, 2004 | 02:36 PM
Twisted99's Avatar
Thanks Sal...Everything arived today like you said....thanks for the effort.
So if it was not running and the ambient temp was 55 degrees....then the intake was seeing good air....even with an open element. Good to know. Seems like the IAT was seeing below 860 degrees...while actual was 55 on the overhead console.....fairly good data....the charge air coolant was warm..but not hot enough for me to flinch when I stuck my finger in the reservoir....pretty effcient.
