Boost gauge true after BB mod?
Old Jan 28, 2004 | 01:08 AM
porsen's Avatar
Question Boost gauge true after BB mod?
Before I performed the simple boost bypass mod, my dash boost gauge would usually only go to about 8-10 psi at WOT. However after the mod the gauge goes off the scale even at somewhat modest accelerations.
Is this expected behaviour?
Old Jan 28, 2004 | 10:56 AM
MISTERgadget's Avatar
Boost Bypass DOES NOT! affect your peak boost level. Cold dry weather will make higher boost levels.
Old Jan 29, 2004 | 01:17 AM
porsen's Avatar
Cold..... yep, that fits the scenario, thx.
Old Jan 29, 2004 | 09:48 AM
LatemodelRacer2's Avatar
You might check into adjusting the bypass. To make shure it letting you get full boost at WOT
Old Jan 29, 2004 | 11:24 AM
porsen's Avatar
Question
Hmmmm....... "adjusting the bypass", not sure how.....The bypass mod is kind if non-adjustable, either it's installed or not. Where and what could be adjusted?
Old Jan 29, 2004 | 10:30 PM
The bypass isnt adjustable and does not affect boost levels at all.
The only adjustment that can be made is to change at which throttle position the valve in the rear of the blower will close to start producing boost. It is best to just leave that alone.
