Pads and Rotors for On track events
Well the season is about upon us and I need some brakes. I cooked my stocks ones last year at SVTOA Invasion @ IRP. I think I just want to go with a direct replacement of rotors and pads. I dont want to have the fade as bad as I did with the stock ones. Any suggestions?
Sean
Sean
Hawk makes a good pad which can also be used on the street. You'll also want to upgrade the fluid when you do pads or you'll boil your fluid. I'd go with Motul 600 if you're changing it out only for the track or Castrol SRF, Valvoline Synthetic, or ATE Superblue if you want a dual-use fluid.
Also check out the Road Racing forum on NLOC. GREAT source of info from those that have been through it all b4
