Need help with OBDII codes
Old Jan 17, 2004 | 11:54 AM
Houndog's Avatar
Getting codes P1324, 0728, 0300. Truck runs but misfires.TIA
Old Jan 17, 2004 | 12:11 PM
billarf's Avatar
Re: Need help with OBDII codes
Go here for easy look up of various Generic OBD 2 Trouble Codes:
http://autoclinic.net/php_test/dtc_search.php
Old Jan 17, 2004 | 12:27 PM
Houndog's Avatar
DTC P1324 Crank RPM Too Low
DTC P0728 Engine Speed Input Circuit Intermittent
DTC P0300 Random cyclinder misfire...
Now what ? I ordered crank sensor,But after thinking this thur, I don't think thats it..
Old Jan 17, 2004 | 06:55 PM
Silver_2000's Avatar
If you google ford odbII codes my site is the 2nd link
http://www.svtlightnings.com/scantoo...tc%20codes.htm
Old Jan 17, 2004 | 07:23 PM
billarf's Avatar
Absolutely terrific Doug! What a resource that is! Thanks!
Old Jan 18, 2004 | 11:52 AM
Houndog's Avatar
Thanks BILLARF and Silver..
BUT, does anyone have an idea what is causing this codes to be thrown ??
Thanks , Ted
Old Jan 18, 2004 | 12:55 PM
I would ask your tuner - But it sounds like a sensor is off...
The engine speed circuit intermittent could be the cause of the other 2.....
If the PCM cant tell the engine speed then its idea of where the crank should be or what a misfire is could be off as well....
Doug
Old Jan 20, 2004 | 01:32 PM
Houndog's Avatar
ATT. JDM
I would ask your tuner ..
Jim,, have any clues as to what is causing these codes ?
Thanks, Ted
