Changed my oil today, Is this normal??
I havn't had it in mine, but I do know that my old Dodge Dakota had the same problem. Dodge actually came out witha baffle setup that went into the filler neck to help stop it. It was on a 4.7 V8
Originally posted by LIGHTNINROD
Note; I am religious about warm-ups in that I start my L up and then drive off. I drive slowly with the OD off for the first 6 or 7 miles, allowing everything to warm up togeather. Then I hit the interstate and 70-85 mph.
Dan
Dan
Originally posted by MHMCGILL
Okay I gotta ask. What is the reasoning for driving with the OD off so that it warms up together? I really want to know.
Also, I have extra 'cold' NGK BR7EF plugs in mine and they tend to misfire if the RPMs are a little too low. I turn the OD off when I'm driving at speeds below 40 mph for that reason too.
Dan
I get the same thing. The filler tube and the breather cap always get gunked up with this crap. Also the vent tube on the driverside going to the intake boot get some along with alot of clean water. I have to empty this tube every couple of days. I think bacause we have our PCV systems altered with, the intake can`t vacoom out the crankcase fumes through the PCV valve itself taking the moisture with it.
Just to keep the engine from lugging when 'cold' . I don't want it in OD and even though I keep the speed low enough, the OD off just makes sure.
Dan
Dan
how long have you had this installed..... it may be causing incomplete crankcase venting....water.., heat it up in some tin-foil
see if its water... [/B]
Oil test best
This looks like antifreeze. Are you loosing anything from the radiator tank or anything from the intercooler ?
Call/write for sample bottle from http://www.blackstone-labs.com/
and for $20 you will know for sure. Generally if there is some antifreeze in there, you will see alot more bearing weat numbers as well.
I posted my '01 oil test info in the used oil analysis (gas engine) forum on www.bobistheoilguy.com. (jeraa2t username)
Good Luck !
Good Luck !
Re: Oil test best
Good Luck !
Good Luck !
Originally posted by Grimace
I wouldn't run penz-crap in a lawn mower. That stuff is the worst thing for you engine. Crisco is a better lubricant.
