Denso spark pugs
Old Jan 8, 2004 | 04:36 PM
cal50's Avatar
Denso spark pugs
Has anyone had one break or go bad? Is there any way to check if the coils are OK?
My truck sputters when I give it more than 1/3 to 1/2 throtle. I just put a Kenne Bell Boost-A-Spark on it and it is not as bad. If I gradually press the throttle to wot there is almost no sputter.
The truck can push 15+psi with the stock Eaton in cool air.
Old Jan 8, 2004 | 04:41 PM
engelmb's Avatar
Re: Denso spark pugs
When was the last time you changed your fuel filter?
Old Jan 8, 2004 | 05:04 PM
cal50's Avatar
I change the fuel filter every 5000 miles and I have never had a clogged one yet.
Old Jan 10, 2004 | 12:40 AM
promodlightning's Avatar
sounds like a burnt plug....
Old Jan 10, 2004 | 01:12 AM
Unoid's Avatar
I had a broken valve spring with those symptons, or could be bad coil pack?
