How much boost does a ported blower add?
Old Jan 8, 2004 | 03:41 PM
captainoblivious's Avatar
Originally posted by Konig
Sounds like a worth while project for once... I have never planned on switching to a KB or Works..its over kill for my uses. How much did it cost, and how long did it take to get it back?
Dude, you missed all the Apten and porting blower threads recently There's almost as many of them as there are SRT-10 threads.
Here's the latest:
https://www.f150online.com/forums/sh...hreadid=141588
Due a search on Apten for more.
03Lightning's Avatar
Easter,
I think that the lightning engine will respond a little different than the Cobra because of the 2 valves vs. 4 valves. The DOHC engines make peak TQ and HP higher in the RPM than the SOHC engines.
Old Jan 8, 2004 | 04:23 PM
Apten_Tech's Avatar
just to clear a few things up
The cobra gains power because of the increase in mostly adiabatic efficiency, so it doesn't gain boost. And because of the gains being mostly abedic, the gains are higher as the RPM increases (low power gains are not high). There is no real boost increase with the cobra supercharger.
The lightning pickup about 1/2 of it's power gains from adiabatic efficiency, but the other 1/2 from volumetric efficiency. This means that the supercharger actually moves more air at the same RPM, creating more boost. That is why the lighting superchargers not only pick up more boost but actually make most of the power gain thru the whole powerband instead of just thru the higher end like the cobra ones do.
Hope that helps.
Brian Herron
Old Jan 8, 2004 | 04:28 PM
easterisland's Avatar
That makes sense because the port job is opening up the intake of the lightning case where the rear entry cobra already has a better opening.
Old Jan 8, 2004 | 04:34 PM
SvtLightning02's Avatar
30 RWHP? thats a lot for just porting..where did that number come from?
I picked up 30 rwhp across the whole field a quick search and you can find my dyno charts i posted awhile back
Old Jan 8, 2004 | 04:35 PM
Apten_Tech's Avatar
exactly!
The outlet work increases adiabatic efficienty, the inlet work increases volumetric efficiency. Since the lightning inlet is so restrictive, there is quite a bit if room for improvment there. While there is some improvment done to the cobra inlet, there is not as much room to grow as there is on the top-fed lightning.
Brian
Old Jan 8, 2004 | 04:39 PM
If you got my chart handy brian post it up it will save me time looking for it
Old Jan 8, 2004 | 05:01 PM
rscoleman's Avatar
By 'abedic' I assume you mean adiabatic efficiency, which is basically the measure of how much a compressor heats the air. I can see why the ported blower would show more gain at higher rpm. With a roots blower, you have lobes trying to move the air around the outside of the case, while at the same time lobes are rising in the center, slinging air upwards into the upper plenum. Eventually the rising lobes slinging the air upwards creates so much turbulence that it robs air from the descending lobes trying to pack the charge around the case and into the engine. Thats why gains from bigger and bigger pullies start to fall off very quickly (10# vs. 4#, for example), combined with compression heat, frictional heat from the internal gears, and shear heat from the air whipping off the rotors. It seems Apten has found a way to scavenge more air to the descending lobes, thus raising the effective rpm potential of the blower before the central rising lobes create too much turbulence.
Old Jan 8, 2004 | 05:33 PM
Red03SVT's Avatar
the air/fuel stays the same?! did I hear that right? how can this be? if more air is being forced into the motor, how can the ratio stay the same?
if this is true, this is really awesome!
-Mike
Old Jan 8, 2004 | 05:40 PM
Apten_Tech's Avatar
the cobras usually have the same air/fuel ratio, the lightnings sometimes do and sometimes they slightly change. It all depends on how close you are to the limitations on your MAF meter and how much boost it's making. Not a bad idea at all to have it dyno checked if you are running a lot of boost or a tune on the edge.
Brian
Old Jan 8, 2004 | 06:07 PM
l-menace's Avatar
I'm a lawyer, not an engineer!
layman terms, so people can understand --> it makes power!
I don't like when people write stuff that the average person (read non-engineer) has difficulty understanding (that's a joke of course)
Old Jan 8, 2004 | 08:24 PM
Rob_02Lightning's Avatar
Or the Below Average People like me I got one big headache ever since the PCV and Apten Post's went overboard
Old Jan 8, 2004 | 08:53 PM
fractaldragon's Avatar
Originally posted by Rob_02Lightning
Or the Below Average People like me [img][/img] I got one big headache ever since the PCV and Apten Post's went overboard [img]]
AMEN TO THAT BRO!
Old Jan 8, 2004 | 10:14 PM
l-menace's Avatar
Originally posted by fractaldragon
AMEN TO THAT BRO!
ditto that!
