Sub Idea?!?
Old Jan 4, 2004 | 10:12 PM
denny0328's Avatar
Sub Idea?!? (PICS)
Well here's the idea I've got.
Im a little further into it, but im waiting till im done and ill do a complete write up...
dennis
EDIT
not sure why the images didnt work, ill try to fix it later...
Old Jan 4, 2004 | 10:39 PM
zbornac's Avatar
here is a how-to write up for an 8-inch.
http://ftw.truckmoxie.com/expyconsolesub.asp
Why not just go behind the seats? Good luck with it.
-Kimball
Old Jan 4, 2004 | 10:41 PM
AmoJohnny's Avatar
cant see nuttin.
Old Jan 4, 2004 | 10:44 PM
zbornac's Avatar
right click the red X, go to properties, and copy the address into your browser.
-Kimball
Old Jan 4, 2004 | 10:50 PM
MaxTorque02's Avatar
It's a slick idea, but I wouldn't think that the sub would perform very well in that small of enclosure and the box wouldn't be very rigid, which is very important for a subwoofer enclosure. What kind of sub is that?
Old Jan 4, 2004 | 11:00 PM
denny0328's Avatar
http://ftw.truckmoxie.com/showownerpic.ten?u=13232&n=362902&pos=1
http://ftw.truckmoxie.com/showownerpic.ten?u=13232&n=362901&pos=1
heres some links to the pics...im gonna post some more in a minute so you guys can see some of the progress ive gotten so far...
zbornac, i saw the write up about the 8", thats where i got the idea, but mines a 10" and it wouldnt fit there, i tried it, so i had to come up with alittle different idea...
maxtorque02, its an eclipse 10"
Old Jan 4, 2004 | 11:08 PM
denny0328's Avatar
try again on the pics...
heres some more pics, if they dont work, ill put a link to them underneath each of them...
i took the white base and cut it in 1/2...
mocked up a cardboard box and sub to fit the pieces...
and built a box to fit...
i fit the boax and it fits in there, eveythings going pretty good so far, im fiberglassing it now, and ive got to get the aft mount back on the box, and attatch the box to the white base...ill post more pics later...
Old Jan 4, 2004 | 11:10 PM
denny0328's Avatar
pics
try rightclicking and hittting show picture, it works for me...
Old Jan 4, 2004 | 11:48 PM
Silver_2000's Avatar
I edited the post to make the links work.....
the various moxie sites dont allow linking in forums....
PS- Does anyone know what moxie means ?
Doug
Old Jan 5, 2004 | 12:46 AM
Doug
Definition of Moxie
Main Entry: ex·per·tise
Pronunciation: "ek-(")sp&r-'tEz, -'tEs
Function: noun
Etymology: French, from Middle French, expertness, from expert
Date: 1868
1 : expert opinion or commentary
2 : the skill of an expert
Old Jan 5, 2004 | 12:48 AM
denny0328's Avatar
Doug,
thanks for the help. for whatever reason they still werent working for me, so i hosted them on my email site and re-did the links...
so know everything should work...heres a link to the rest of the pics of you guys want to se them....
http://members.***.net/d.byington
Old Jan 5, 2004 | 12:49 AM
One thing you will have to work hard at, is geting all the rattles out of the console. With a sub in there it's going to vibrate pretty good. I would coat the inside of the console and the outside of the box with dynamat or similar material. Looks good so far.
Old Jan 5, 2004 | 12:54 AM
denny0328's Avatar
rattles is one thing im definately worried about. Im going to wrap the box in fiberglass atleast 3 times to try to get it as stable as i can.
and after i get everything put together i was thinking about turning it upside down and spraying in that expanding foam (cant think of name right now), in it untill it overflows, and then triming the excess. i hope that might stop some rattles. dynamat might end up going on the outside of the box before i install it depending on how much room is left on the sides...it was a pretty tight fit already, thats why im hoping the foam works.
Old Jan 5, 2004 | 12:00 PM
brain bypass's Avatar
try some of this stuff, its cheaper than dynamat. check out the "rattle pad"
http://www.secondskinaudio.com/secondskin.html
Old Jan 5, 2004 | 09:30 PM
RollinLimp2001's Avatar
I liked the idea of the 8" in the console but wanted something bigger as well. I knew JL Audio made boxes for Ford consoles but they don't have one for the console that's popular for our console mods. Couple questions for your setup...Is there enough space between the sub and the floor so that it's not going to hit the floor? What are the dimensions for that box? Looks a little small to me for a 10". Would be pretty sweet if you ported it and had the port come out the rear air control slot of the console. Good luck...Keep us posted!
