4 # lower pulley help PLEASE!!
Old Jan 2, 2004 | 05:08 PM
svtjulian's Avatar
Hello everyone!! I just recently bought a JDM 4# lower pulley used on ebay. Will I need a different belt size?? If so could anyone tell me which part# please. Will I also need special tools?? And will it be better if I get a chip for this bolt on or will it runs good as is?? I have a hypertech programer, a JDM intake kit, boost bypast, Denso iridium IT16's spark plugs, and a 160 degree thermostat. I ran 13.48 @ 102 in the 1/4 mile, what times would be possible with the pulley??? Thank you everyone your help is appreciated!! happy holidays everyone!!:santa:
Old Jan 2, 2004 | 05:16 PM
Justin@JDM's Avatar
Banned
svtjulian,
With the four pounder you can use the stock belt if you wish. If you do want to move to a new belt you would want the Gates K080670. If the Hypertech is not programed for the extra 4 pounds of boost I wouldn't use it and go with a chip instead. You should easily drop to a 12 second truck with these parts.
Hope this helps,
Justin@JDM
Old Jan 2, 2004 | 05:22 PM
ShaneMcKenna203's Avatar
I have a jlp 4# lower and it came with a 4080680. Enjoy the new found boost...
Shane
Old Jan 2, 2004 | 06:25 PM
wydopnthrtl's Avatar
4# here. Either run the stock computer or step up to a chip that is calibrated for a 4#.
Rich
Old Jan 2, 2004 | 08:33 PM
BDAZSVT's Avatar
I have a 4lber on order and my chip is being reburn. How much differance does the pulley make? I can hardley wait to get it. When I do get it on there will probably be snow on the ground. Last spring I ran an 8.54@83.64mph with a 2.02 60' and I am hoping the pulley and traction bars can get me just one pass in the 7's 7.999 will work.LOL
Old Jan 2, 2004 | 08:41 PM
fractaldragon's Avatar
I have a JDM 4# and chip and ran the times in my sig with a 1.89 60ft. Also have Lakewood traction bars. My 1/8 mile was 8.18 at 85.70 mph on that run. Good luck getting a 7.999 in IN! My truck is a factory freak (see dyno #'s) and I had and exceptional 60ft time on F1's. You'll see a 7.999 on slicks, but not on F1's IMO.
To answer the original post, I use my stock belt with the JDM 4# no problem. You'll probably see a gain of 2-4 mph.
Old Jan 2, 2004 | 09:10 PM
BDAZSVT's Avatar
fractaldragon: thats my goal is the 7 second pass. The track is pretty crappy but is only 385' above sea level and maybe a good tailwind.... I dont want to go to slicks I may go to a drag radial though depending on funds
Old Jan 2, 2004 | 09:20 PM
What track is it? I goto US41 usually. They are open all year round too Have you dynoed at all?
Old Jan 2, 2004 | 09:31 PM
Blown93's Avatar
I ran a 12.60 on F1's with a chip and a 4 lbs pulley and filter kit..... no other mods.............
PEacE.....................
Old Jan 2, 2004 | 09:45 PM
Rob_02Lightning's Avatar
Like everyone is saying
12's are quite achievable with a simple filter-chip-n-4lbs,
however I WOULD NOT "under any circumstance",
run a 4lb pulley with #16 plugs.
Denso IT 22's would be the SAFE choice,
some may say stay hotter w/20's, either way #16 is wrong.
And yes you need two tools
One to lock the flywheel from turning,
and one to remove the old pulley.
Here's a Step by Step with Pictures
Hope it helps
GOOD LUCK
http://www.fastndelirious.com/forums...s=&threadid=85
Old Jan 2, 2004 | 09:49 PM
BDAZSVT's Avatar
fractaldragon:Greater Evansville Raceway, I am supposed to go to the Dyno this spring with a friend, Powerdyned 4.3 S10. I am at the southern tip of IN, I can see Kentucky litterally.
Rob I plan on putting my Tr6 's back in?
Old Jan 2, 2004 | 09:58 PM
tallimeca's Avatar
not to be negative
1.89 is no great accomplishment, even though my best on f1's is in the mid 1.9's.
But since i still can't launch my truck on slicks, who am I to point fingers...........
Old Jan 2, 2004 | 10:02 PM
Re: not to be negative
Well considering it was on a chilly day and I was forced to go through the water box and there was no VHT down...yeah it was exceptional hehe
Old Jan 2, 2004 | 11:58 PM
svtjulian's Avatar
Thank you everyone you have been very helpful!!
