Belt Size?
Belt Size?
I recently bought the metco idler pulley kit that makes the belt wrap around the top pulley better.
I also have a 2 lb lower pulley. I am using the stock belt with the 2 lb. lower but I haven't installed the idler kit yet.
Any body have any idea what size belt I will have to go to once the idler kit is installed.
Chris
Chris
I don't know if this will help you or not, but I am very confident your current belt will not fit.
I have a 3.20" upper and a 9" lower (2 and 6 lb). I was using a 85 and once I installed the Metco I went to the 95 series. I can't remember the first 4 or 5 numbers to the belt size (gater belt), just the last two. Sue over at JLP helped me out with the necessary size.
Good luck!
D-Day
Good luck!
D-Day
