Which gauge pod is the best
Old Nov 22, 2003 | 06:58 PM
tlfwatch's Avatar
Question Which gauge pod is the best
Looking for gauge pod that will look factory for my lightning i know they are some good companys out that manufacture them also gauges that will match my dash. thanks for your replys?????
Old Nov 22, 2003 | 07:09 PM
LightningCT's Avatar
should've done a search.....but since you didn't, - the Autometer lunar gauges "match" our dashes (slightly).
You can get them at RPM Outlet (http://www.rpmoutlet.com/lightning.htm) and REM (http://www.razorsedgemotorsports.com..._frontdoor.php)
RPM outlet has a matched gauge pod that is supposedly the same color as our interior.....
Old Nov 22, 2003 | 07:21 PM
SLVRLTNG's Avatar
I personally like the autometer Phanton series gages.....
Old Nov 22, 2003 | 07:38 PM
Lightningquick's Avatar
The cleanest looking is the lo-tek gauge pillar.But im not certain it will fit the 02 and 03s due to a a slight change in truck manf.Otherwise it is an exact replacement.
The autometer is probally the most common but the only draw back is the way it is mounted.It has 4 small pins that are barely visable and you have to hack into the factory one to run wires......so if you decide to take it out you need to get a new factory one too.
ALL of them are a biatch to get matched.The lotek comes grey.that is a BIG plus............... www.lotek.com ??
Old Nov 23, 2003 | 11:12 AM
tlfwatch's Avatar
Question Follow up question changing pod
how is the pod connected should not be a problem changing it out i would think what holds it screws etc/ i am going to go with two gauge pod with oem grab handle made by lo-tec already painted to match our gray colors
Old Nov 23, 2003 | 12:48 PM
Tim Skelton's Avatar
Re: Follow up question changing pod
Is there a question in there somewhere?
