Check out this dash setup!!!
Old Nov 22, 2003 | 04:11 PM
AutoPCSystems's Avatar
very simple
...still waitin....
Old Nov 22, 2003 | 05:48 PM
LightningCT's Avatar
that's some nice bondo work.....pretty sweet!!
Old Nov 22, 2003 | 06:00 PM
Nefarious's Avatar
Originally posted by AutoPCSystems
...still waitin....
I'll take a stab at it...
Just use the power save function in windows triggered by a relayed ignition pulse. This would allow you to have the system go into standby mode when the vehicle is turned off saving all your current session information. Once triggered again by turning the car on, the system would turn back on with all the prior information still active.
Most PC's and laptops have this function available in the later versions of windows.
Old Nov 22, 2003 | 06:11 PM
thats good but then you have to have constant power to the pc correct?
Old Nov 22, 2003 | 06:21 PM
Nefarious's Avatar
Correct, but that's not an issue. All stereo's have constant power going to them inorder to retain the clock and preselects.
The same thing applies to the cpu power source. Just wire the power inverter to not shut off with ignition. The draw is so minor that it wont effect the vehicle.
BTW, I'm a former installer
Old Nov 22, 2003 | 06:25 PM
i actually used an inverter so that all the other peripherials would be able to be used without disecting them...so the problem in my case would be keeping the inverter on all the time...the draw is more than minor at that point...
Old Nov 22, 2003 | 06:27 PM
oh and something else, the power surge caused by the starter kills most computers...how would you handle that?
Old Nov 22, 2003 | 06:32 PM
RipNRun's Avatar
Here's a stab at it...
Why not a rechargable battery backup for the PC connected to the inverter, ala a laptop? Then it can sleep whenever the power is cut.
--Rip
Old Nov 22, 2003 | 06:35 PM
battery backups dont work with square wave current, which is what inverters put out...see, its tricky!
Krix330cic(NJ)'s Avatar
what a great idea...too bad no one in the L community has thought of sucha thing
dont be so humble!
you know your chit is tight!
maybe ill pick your brain for ideas to add to my "backseat" project..
Old Nov 22, 2003 | 06:37 PM
Originally posted by swiseuf
krix(?) is close with his HD truck. He did some neato custom stuff, but I dont think he put a computer in his. I love it when people have the vision to try things like that.
thanks man.. im happy with how phase one turned out, i learned a lot from that project.
i think the wife would kill me if i was online in the truck next.. its bad enough all the time i spend while at home..
Old Nov 22, 2003 | 06:38 PM
hmmmm..."backseat " project...
Old Nov 22, 2003 | 06:39 PM
Nefarious's Avatar
Simply add a battery backup/surge protector. I'm not seeing the problem here with a daily driven vehicle that is started at least once a day.
...and yes they will function in a car. My shop has used them several times.
Old Nov 22, 2003 | 06:40 PM
the most fun i had with being online was having streaming video as i drove...way cool...broadcast live SVT events real time too...
Old Nov 22, 2003 | 06:43 PM
battery backups done work with squarewave current! so you cant use one as long as u are using an inverter...and if you plan on adding such things as printers, wireless lans, usb hubs, etc, it makes it much more convenient to have an inverter available...btw i'll be back in a few hours to check how the class is doing..
