blinker on mirror out
Old Nov 18, 2003 | 04:08 AM
01FordLightning's Avatar
my blinker bulb on my left mirror dosent work and the silver part is loose dont know how to get it off or tighten it and i dont know how to fix the bulb'
thanks,
justin
Old Nov 18, 2003 | 09:43 AM
Fordsrus's Avatar
To get to the bulb. First put the mirror in the down position. Now look between the mirror and you will see two tabs(the same color as your truck) take a screw driver and lift them up. This will remove the painted part of the mirror. The bulb # is a 921 16W
Ryan
Old Nov 18, 2003 | 09:57 AM
LatemodelRacer2's Avatar
You might just need to change the Blinker fluid
Old Nov 18, 2003 | 10:26 AM
swiseuf's Avatar
I had the same problem on my old truck. Be careful not to spray water directly behind the mirror when you wash your truck like I did....
