Sick of my stupid a$$ truck constantly pinging!
Mine was pinging real bad at WOT, even from about 65 MPH, if you stomped it, it pinged. I just casually mentioned it ot Mike Troyer and he told me to try a different gas, (Sunoco 94 if you can get it) and it fixed it, right away. He told me if I couldn't get good gas, to try ading some octane booster to it. Just using a high octane is not always good enough, I was using BP 93 and it was pretty bad, but since I swithed to the Sunoco, it't been fine.
Hope this helps,
G
Hope this helps,
G
i live in ca where the highest octane pump gas i can get is 91, and i really dont want to have to constantly be mixing race feul into the tank, it's too heavy on the wallet.
I want to be able to run on just pump gas and not ping like mad. right now i am running on only 11* of timing which is rediculous, i need to solve this problem.
What are your air/fuel ratio(s)?
Did it ping before the 6 lb pulley and chip were installed? Your stock 1/4 mile numbers look good?
The BR7EF's and the 160 degree 'stat should be helping. Those are COLD plugs(I like mine.)
A restricted exhaust can cause pinging but I would doubt that for such a 'new' L??? Carbon buildup in the combustion chambers can cause it too but again; it's too new.
Dan
Dan
