Please help whats wrong
Old Nov 16, 2003 | 01:03 AM
johnathanh's Avatar
Unhappy Please help whats wrong
Hey guys
I went to the track again today and ran 1/4 mile best 14.9x sec
i had good traction and i've changed the fuel filter yesterday
and no check engine light
My truck is mostly stock It has only a knn filter with air box mod and boost bypass The truck has only 23550 miles on it
It was 85 deg
Please help
Whats wrong whith my truck???
Old Nov 16, 2003 | 02:15 AM
superfords's Avatar
it's in aruba?
Old Nov 16, 2003 | 04:05 AM
clonetek's Avatar
tell us exactly what your timeslip says...
Old Nov 16, 2003 | 04:07 AM
Probleminfected's Avatar
driver error? clogged inner cooler? track isn't prepped right? massive belt slippage?
could be a bunch of stuff
Old Nov 16, 2003 | 08:36 AM
CCCPL's Avatar
I would think living in the ABC islands, is like it is here in Florida, hot most of the time! My truck runs so much faster now that the temps are in the 50's.
In the summer with temps around 85 to 95, my truck runs like a slug!
Chas
Old Nov 16, 2003 | 01:02 PM
johnathanh's Avatar
Heres my time slip
60 ft 2.242
330 ft 6.328
et @ 594 ft 9.061
1/8 mile 9.668
1/8 mph 74.11
1/4 mile 14.965
1/4 mph 92.60
what do i have to do to find out if my intercooler is glogged?
Old Nov 16, 2003 | 01:13 PM
12leavu's Avatar
pull your blower off. The intercooler is underneath it.
Your floormat wasn't hung under your gas pedal was it...j/k
Old Nov 16, 2003 | 02:22 PM
DL's Avatar
DL
Originally posted by johnathanh
Heres my time slip
60 ft 2.242
330 ft 6.328
et @ 594 ft 9.061
1/8 mile 9.668
1/8 mph 74.11
1/4 mile 14.965
1/4 mph 92.60
You must have been spinning tires to get a 2.242 60'
Drive around the water box, heat the tires up dry.
Try launching at 1,000 RPM.
Intercooler clogged
Never heard of that one before...
let us know...
Old Nov 16, 2003 | 04:12 PM
johnathanh's Avatar
I've had my tires at 16 psi
i had a passenger with me.
she told me that at third speed the tires werespinning
but when i launched the tires werent spinning
and i dont think the intercooler is clogged because the liquid in the intercooler reserve tank were moving
Old Nov 16, 2003 | 04:20 PM
ICULOKN's Avatar
Heres my time slip
60 ft 2.242
330 ft 6.328
et @ 594 ft 9.061
1/8 mile 9.668
1/8 mph 74.11
1/4 mile 14.965
1/4 mph 92.60
Ok,
2.2 60 foot means you are spinning or not getting all the way on it!
92 mph in the 1/4 is WAY low... Are you holding the gas all the way through the 1/4?
Now you also say you have a boost bypass. Is it installed right? Maybe your bypassing the boost ALL the time?
Old Nov 16, 2003 | 04:25 PM
Txoutlaw's Avatar
Heres my time slip
60 ft 2.242
330 ft 6.328
et @ 594 ft 9.061
1/8 mile 9.668
1/8 mph 74.11
1/4 mile 14.965
1/4 mph 92.60
Looks very similar to the times I was running when I first purchased my 03. Turns out the intercooler wasn't working. Crank up your L, let it run for about a minute then look at the intercooler de-gassing tank (it's on the passenger side next to the radiator). If you don't see any bubbling then your intercooler isn't working. I actually ran a 15.2 in the 1/4 and my 60ft was 2.2. After the the intercooler was fixed I ran a 14.1 and my 60ft was 2.0.....this was driving 2 hours to the track, no cool down, about 87 degrees and about 85% humidity. Huge difference! The master mechanic at the dealership told me that without the intercooler you loose about 65 HP. I don't know that to be a fact but that is what he said. Good luck!
p.s. If your intercooler is clogged, you probably won't see any bubbling in the de-gassing tank or it will be very little.
Old Nov 16, 2003 | 04:36 PM
DL's Avatar
DL
Don't forget to push the button for your Tranny Overdrive switch to off.
johnathanh's Avatar
Originally posted by ICULOKN
Ok,
Yes i was holding the gas all the time
Yes i have boostbypass i have unplugged the wire
My intercooler de-gassing tank is bubbling
Old Nov 16, 2003 | 04:37 PM
DL's Avatar
DL
Keep practicing, sounds like everything is working OK.
johnathanh's Avatar
yes i did that
