Please help whats wrong
Old Nov 16, 2003 | 04:40 PM
johnathanh's Avatar
Originally posted by DL
Keep practicing, sounds like everything is working OK.
ok. thanks man
i think maybe the weather is affecting me
Next yeat i am going to order a 6# pulley and have it dynotuned
Old Nov 16, 2003 | 05:02 PM
Probleminfected's Avatar
the inner cooler still could be clogged with oil, i'm not talking about the lines, i'm talking about the inner exchanger fines. you'd have to removed the s/c to find that out
that tire pressure is too low too
Old Nov 16, 2003 | 05:25 PM
fractaldragon's Avatar
Originally posted by ICULOKN
Ok,
2.2 60 foot means you are spinning or not getting all the way on it!
92 mph in the 1/4 is WAY low... Are you holding the gas all the way through the 1/4?
Now you also say you have a boost bypass. Is it installed right? Maybe your bypassing the boost ALL the time?
MPH is low the whole way...look at the 1/8 mile MPH at 74...I averaged about 6 mph faster than that at just the 1/8 mile mark
Old Nov 16, 2003 | 05:37 PM
johnathanh's Avatar
and if i flush the intercooler?
Old Nov 16, 2003 | 08:06 PM
TiresWinRaces's Avatar
MPH is way, way low. Is the boost gage showing boost during the run. You should be hitting 8 psi stock.
And 16psi for tires? I assume you are running slicks then? If you're on street tires, that is way, way too low. Try about 28psi.
Old Nov 16, 2003 | 08:22 PM
johnathanh's Avatar
yes my gage was showing 10 psi
I was running with nittos nt 555
Old Nov 16, 2003 | 08:26 PM
You should be easily in the 1.9's or even 1.8's on Nittos. A tenth of 60' time is roughly equal to 2 tenths ET. If you nibble that 2.2 down to a 1.9, you'll be in the low 14's. Keep practicing the launches.
Something still sounds wrong with the low MPH though.
Old Nov 16, 2003 | 08:39 PM
LIGHTNINROD's Avatar
As others have said, your MPH's are way too low, indicating a loss of horsepower.
Engine lacks power--possible causes:
1. Incorrect ignition timing(I doubt that?)
2. Faulty or incorrectly gapped plugs(shouldn't be that with your mileage?)
3. Air filter dirty(very well could be?)
4. Faulty ign. coils(doubt that or your eng would be misfiring)
5. Brakes binding(???)
6. Auto. trans. fluid level incorrect, causing slippage(???)
7. EGR system not functioning properly(???)
8. Use of sub-standard fuel(pinging???)
9. Vacuum leak(s) at hose connections or manifold(???)
10 Dirty or clogged fuel injectors(???)
11. Restricted exhaust system(doubt it???)
Dan
Old Nov 16, 2003 | 09:00 PM
Don's Bolt's Avatar
To me it sounds like High humidity, and **** poor track prep
Humidity kills e/t more than heat, and who knows how well they prep the track down there.
Old Nov 16, 2003 | 10:00 PM
johnathanh's Avatar
ttt
Old Nov 18, 2003 | 12:35 PM
HEVYRESQ's Avatar
Were you driving with your doors open????
Sorry bro, just keeping your post fresh for ya
Old Nov 18, 2003 | 01:07 PM
MHMCGILL's Avatar
I'm sorry if I missed it, but did anyone mention the fuel filter, checking it that is?
Old Nov 18, 2003 | 03:02 PM
skennett's Avatar
Don't forget to push the button for your Tranny Overdrive switch to off.
You're kidding right?
--Steele
Old Nov 18, 2003 | 03:04 PM
skennett's Avatar
johnathanh,
Shoot me an email (steele@denimgroup.com) so we can talk about this. I'll help you out any way that I can.
--Steele
Old Nov 18, 2003 | 06:24 PM
Fear Itself's Avatar
What about the quality of the gas available there? It's probably not the only cause of your low speeds, but if your gas there is less than 93 octane, that could have something to do with it.
David
