Question on balancing Bogarts.
Ok, I have all four of my wheels now. Sent them to get mounted and balanced. I asked to have the weights as far back as possible. Well all but one still hit the calipers. Are you guys having hammer on weights used in the back or what are you doing. The said if I had any problems then they would use hammer on weights in back, but that isn't the best way to balance a wheel which I can understand. Any help would be greatly appreciated as I need to get this done ASAP. Thanks, -Mat-
Originally posted by Don's Bolt
Yes I used hammer on weights on the back side of my rims. Then I used the silver metal duct tape to hold them on better.
Originally posted by SVT F15O
Thanks Don! If that is good enough for you then it is good enough for me! Just wanted to make sure someone else runs with no wieghts on the front before I do. Off to the tire shop tomorrow. Thanks again. You coming down to Cecil this weekend>??? Would be great to see ya there. -Mat-
I run weights on both side of my rims, but I used the bang on weights.
Just make sure they use the right bang on weights, since it is a thin rim.
