expected 1/4 times and hp/Trq from these mods???
Post subject: expected 1/4 mile times and HP/Trq with these mods
3# lower 2# upper on a Eaton
JLP Ram Air intake system with Filter kit and outerwear
90mm MAF
Phenolic Spacer
boost bypass/Oil seperator (I know they don't add power)
E-Fan
Cobra R water pump
Apten ported Eaton Supercharger (40rwhp on cobra)( www.apten-us.com )
Homemade power cooler ( http://www.nloc.net/forum/showthread...threadid=24290 )
Superchip Flip Chip (dyno Tuned, street/race)
FT V/B
Deep trans Pan
Lakewood Traction Bars (might update to JLP or PSP Lifter bars)
Hoosier 28x16x10 SLicks
MAC Cat back
What are your guesstimates on 1/4 mile time and hp/trq at rear wheels.?
With the following it made 389.7hp and 499 trq at rear wheels.
street side of chip, 3# lower, Airraid intake, 90maf.
(stock exhaust and original fuel filter)
Never dyno'd the race side of the chip!
with these mods it ran a 13.056, AND A 13.058 back to back
_________________
Friends don't let friends drive stock!
Ford voided my warranty for using aftermarket AIR in my tires.
90mm MAF
Phenolic Spacer
E-Fan
Cobra R water pump
FT V/B
Deep trans Pan
MAC Cat back
_________________
I'd agree, 12.3 - 12.5
I ran 12.8's with filter chip n 4lb
12.7's when I added the Accu Fab
No cooling, pump, fans, spacers, porting, tranny, suspension,
or exhuast Mods. You should be at least 3 - 5/10's faster
all those mods and it only ran 13.05 dam* my truck is practicaly stock and ran 13.26, 13.29 and 13.31 in one day. are you spinning real bad or what? cause you should be running in the mid-low 12s easy.
I was like WTF.... that has to be within my first 100 posts.
Remember I had 3.55 gears.
and I was spinning off the line.
However I only had a 3# lower and stock upper. and I don't think I had the eaton ported at that time...
