Dumb questions...
Old Oct 31, 2003 | 02:49 PM
SLVRBLT's Avatar
Dumb questions...
First of all...What does ttt mean?
Secondly...I bought a 4lb pulley and a dual program superchip and I'm getting a little detonation at WOT. Will changing out the plugs to NGK TR6's (have in my garage, just no nutters to dive in and change them) help with detonation?
Any help is appreciated...
Old Oct 31, 2003 | 02:52 PM
blowntruck's Avatar
Well, I do know TTT means " to the top".
Old Oct 31, 2003 | 03:05 PM
RhinoSlug's Avatar
From my readings on this board, it is not recommended to run the stock plugs with additional boost. I would definately take some time to put in the Tr6's which run a cooler then the stock ones. It isnt that difficult. There are alot of threads with helpful info on changing them. Go out and do the front passenger side. It should take you no time to do that one. And if you feel comfortable doing that one, all the others are the same except for the accessiblilty. But its definately doable. Do some research on this board first. Here are my tips
Have plenty of extensions,
Use some sort of tape to tape the extension to the sparkplug socket,
Go quarter turn to tighten coil packs, 1/8th turn for sparkplugs,
Old Oct 31, 2003 | 03:29 PM
LightningCT's Avatar
is that true....if we are running more that stock boost, we should have different plugs....and who do i know if i am detonating (what does it feel/sound like)......thanks
Old Oct 31, 2003 | 03:36 PM
captainoblivious's Avatar
I would definately recommend changing the plugs.
As for it helping detonation, I'm not sure if that would fix it.
Were do you live? Different parts of the country have different gas. A chip that works fine on gas in one place may detonate in another.
If you area typically has bad gas, try and find a place to get better then average for your area. Also get your chipped reburned and make sure you let the tuner know the gas quality and mods.
Old Oct 31, 2003 | 03:44 PM
DEIMATT's Avatar
Denso IT 20's they are just a freaking Steal of a Deal at 90 bucks for a set!!(sorry lol)
Change you plugs!!! GOd Man change your plugs!
Old Oct 31, 2003 | 04:04 PM
I live in CT, and i get gas at the same gas station every week (well actually like every other day...lol), but would i be able to tell if there was detonation?? and what plugs would you recommend with my mods....thanks....
Old Oct 31, 2003 | 04:09 PM
engelmb's Avatar
Best bang for the buck are the NGK TR6 plugs. Should be able to get the at your local autoparts store. I had a similar problem with the same kind of mods and changing the plugs fixed it. YOU HAVE TO CHANGE TO PLUGS WITH THESE MODS DUDE. Hope this helps.
Old Oct 31, 2003 | 06:03 PM
I'd recommend the TR6's also. If you don't mind paying more then the NGK's, search through old posts to look for the recommend Denso's for your mods. A lot of people swear by them.
Old Oct 31, 2003 | 11:58 PM
Thanks guys....fun little project for the weekend (i hope??)......
Old Nov 2, 2003 | 01:09 AM
Do a search and read through past posts, take your time and be carefull. Those 2 things will make spark plug changes much easier. It's more intimidation then it is hard.
Old Nov 2, 2003 | 06:50 AM
Rob_02Lightning's Avatar
This is true, but our plugs are a Mo Fo compared to what
most are use to, especially those back two
But like everyone said
IT MUST BE DONE
and remember DETONATION KILLS,
go extremly easy on it til the Detonation IS GONE
Here's a little 2 part movie and lots of great info by Chuck
http://home.midsouth.rr.com/lightnin...parkplugs.html
