lowered truck problem
Old Oct 30, 2003 | 01:00 AM
ub2slo's Avatar
I installed the Roush kit on my truck about 2 months ago, and got the alignment immediately after the installation. I recently noticed that the inner part of my front tires ( new mind you ) are worn to the metal lining. So I'm like WTF, I'm going to take the truck back to the shop that did the alignment to fix it for free, but what I want to know is that if there is a kit/bolts that minimize this from happening?
Old Oct 30, 2003 | 01:05 AM
Probleminfected's Avatar
well you had to much negative camber.
they would have had to put in cams to fix it so no worries, you might want to get your alignment checked at a different shop
Old Oct 30, 2003 | 01:51 AM
zbornac's Avatar
I have had the same problem. It ate a pair of F1s, and now it is working on some Dunlops. Thing is, I am within spec on camber, and cannot get any more out of my cam bolts I have (NAPA). What is going on?
-Kimball
Old Oct 30, 2003 | 02:00 AM
do you have two cams or four
if you have four you should be able to get into spec without problems
you can put one in each bolt hole on the a-arm
Old Oct 30, 2003 | 03:03 AM
zbornac's Avatar
I bought 2 NAPA kits, so whatever is included in those. I honestly can't remember being I put em in about 2 years ago.
-Kimball
Old Oct 30, 2003 | 10:05 AM
TampaBlack99's Avatar
I had tons of alignment problems with my truck until I found a guy that specializes in aligning lowered vehicle. They need to account for the roads in your area... Florida has crowns in the road for water runoff that will greatly effect an alignment. Since having my truck aligned at this new shop I have had no problems. My truck has a 4/4 drop and I only have a little wear on the inside, but this is do to the several drop I have. Most Ford/Quality Care centers will not correclty aligned a lowered vehicle. They will use stock alignment specs which is wrong!
I would HIGHLY recommend finding a local dropshop that does alignments also.
My drop consist of:
Western Chassis 2" Drop A-Arms
Western Chassis 1" Drop Spring
Western Chassis C-Notch (Not in yet)
Western Chassis Hangers and Shackles
Doestch Tech Shock
So-Cal Rear Adjustable End Links
Energy Suspension Bumpstops and Front Endlinks
Old Oct 30, 2003 | 10:31 AM
ShadowBolt's Avatar
I have the Roush lowering kit and have had no uneven tire were in 11,000 miles. I got my alignment specs from Eric at Roush. I would think Roush would know what these trucks need with their kit more than anyone else.
Jerry
