Noisy Hawk HPS pads
Old Oct 28, 2003 | 05:31 PM
Edward's Avatar
Angry Noisy Hawk HPS pads
I installed some Hawk HPS rear brake pads a couple of weeks ago on my truck. This week, they've begun squealing like pig with its nuts stuck in the fence. They don't seem to sqeal during high speed braking; but at low speeds, it's quite embarrasing. Any suggestions?
Thanks,
Edward
Old Oct 28, 2003 | 05:37 PM
beastie's Avatar
Did you put the disc brake quiet goop on the back of the pads?
Old Oct 28, 2003 | 06:05 PM
ShadowBolt's Avatar
Edward,
What beastie said. It works!
Jerry
Old Oct 28, 2003 | 06:06 PM
captainoblivious's Avatar
Aren't the Hawk HPS pads more of high performance pad that is made to work better at a higher operating tempatures? Or am I thinking of the Hawk Blues?
High performance pads usually squeal a little when they are below their optimal temperature range.
Old Oct 28, 2003 | 06:10 PM
l-menace's Avatar
I had Kevlar pads once on another vehicle and they didn't work when cold!
I would run the first stop sign every morning.
once they heated up, HOLY COW. talk about stop on a dime!
Old Oct 29, 2003 | 11:00 AM
SVT_KY's Avatar
Kevlar rocks ... But NOT cold ...
Did you bed them correctly ????
Old Oct 29, 2003 | 11:04 AM
skennett's Avatar
Re: Noisy Hawk HPS pads
Thanks,
Edward
A couple of real hard stops will get rid of that.
--Steele
Old Oct 29, 2003 | 01:34 PM
Steelgrave's Avatar
Thanks,
Edward
All I can say is get used to it. I had those pads on my 03GT before I got my L, and they have this range they'll squeal in. Very light braking or very hard breaking they were quiet as could be, but in between they were loud a *****, and nothing got rid of it.
I just turned the stereo up and didn't worry about it. (I actually got used to it) If that fails, save them for the track and put a true street pad on...
Old Oct 29, 2003 | 04:32 PM
2002Bolt's Avatar
My stock ones have a range where they make some noise not a lot but a little, does anyone elses stock pads do that?
Old Oct 29, 2003 | 05:13 PM
LIGHTNINROD's Avatar
I changed my OEM pads out at 42,000 miles for NAPA's Ceramix pads. Neither have squealed--no noise at all.
Dan
