MAF question
Old Oct 28, 2003 | 04:17 PM
silverzz28's Avatar
MAF question
stupid question.......
Is the Electronics the same in a 80 and 90mm Maf?
If so A buddy of mine can make the housing!
Old Oct 28, 2003 | 04:22 PM
99svtlightning's Avatar
Even if it's not, the MAF isn't something you want to play with. Changing the size or the meter, sample tube, and electronics can play havoc on your A/F ratio. I'd recommend going with a 90mm and let your tuner know so they can adjust your chip.
Old Oct 28, 2003 | 06:26 PM
12leavu's Avatar
I wouldn't be playing with it. If the sample tube were the same for an 80 and a 90 I could duplicate the housing of a 90, that would look and flow beter than factory, while using the stock sample tube. I have a tune for a 90mm currently, but if the electronics aren't the same, oh well I'll buy a 90mm. Can anyone answer the question? Are the sample tubes the same?
