Check Engine Soon Light??
Old Oct 27, 2003 | 09:05 PM
StrukbyABQ's Avatar
Well it came on today and when I checked it the OB said "Running too Lean"..I put a Power Pipe on it about 3 weeks ago and no prob When I called the tuner He said He did burn it for that Pipe?? but its gettin colder 38` degrees here this morning would this effect it or does Anyone have any other advice???
Struk
Old Oct 27, 2003 | 09:18 PM
cpeapea's Avatar
do you change your fuel filter on a regular interval?
Old Oct 27, 2003 | 09:22 PM
StrukbyABQ's Avatar
No not since Ive had it, 5000 miles on it as of late.
Vinny's Avatar
YOu could have messed up your maf sensor. or unrelated to your power pipe install check your 02 sensors if u just put headers in. Did it say lean bank one or lean bank 2???
Vinny
Old Oct 27, 2003 | 09:27 PM
StrukbyABQ's Avatar
It said Bank 1
Vinny's Avatar
did you put headers in recently?
Vinny
Old Oct 27, 2003 | 09:30 PM
Vinny's Avatar
If is says bank one it means it is after your engine not before i think. Correct me if i am wrong anyone. Bank 1 means it is what sounds to me like an 02 sensor on the passenger side. I forget if bank one is passenger side or driver side. Try switching your o2 sensors and see if it comes up bank 2 . then you know it is bad.
Vinny
Old Oct 27, 2003 | 09:34 PM
StrukbyABQ's Avatar
Thanks.. Guys it seems to be the consensus.. I did put on Exhaust about a month ago I noticed a couple small leaks I'll fix but This is all new to Me so Its depressing..
Old Oct 27, 2003 | 09:37 PM
Vinny's Avatar
Hey man, youll get it straightened out. Dont worry it is a small fix. A new 02 sensor is like 100 bucks. Good luck. It will be fine.
Vinny
Old Oct 27, 2003 | 09:44 PM
StrukbyABQ's Avatar
Thanks a Shizload Vinny.. What makes them go out it being a new truck and all anyway??::
Old Oct 27, 2003 | 09:52 PM
Vinny's Avatar
u said u did a full exhuast right? If so, you could have pinched a wire putting the header in or damaged it putting the header in or the wiring is hitting the new header causing it to melt the casing and shorting it out.. Other than that, i dont know. Remember, it might not even be that. That is just my assuption and a starting point. If u did a full exhuast, that is what i would assume. IF u just did a catback, then it shouldnt be that.
Vinny
Old Oct 27, 2003 | 10:20 PM
StrukbyABQ's Avatar
Just a Catback
Old Oct 27, 2003 | 10:45 PM
Vinny's Avatar
I am not sure now? It sounds like an 02 sensor but with just a catback.... Hmmmmm. I am not too sure. Hopefully someone else will chime in.
Vinny
Old Oct 27, 2003 | 11:02 PM
StrukbyABQ's Avatar
Thanks Again Vinny...
