anyone ever lower compression and boosting more PSI?
Old Oct 25, 2003 | 03:53 PM
l-menace's Avatar
Anyone?
I know JL is running a stocker motor, but don't know what he is running for compression ratio.
But has anyone lowered the compression ratio nand realy turned up the boost?
friends don't let friends, drive stock!
Ford voided my warranty for put aftermarket AIR in my tires.
Old Oct 25, 2003 | 05:18 PM
rscoleman's Avatar
You don't need lower compression to run lots of boost.
Old Oct 25, 2003 | 05:52 PM
l-menace's Avatar
true, but if you lower the compression think about how much bost you can run, lets say "twin turbo"
Old Oct 25, 2003 | 07:13 PM
Bad as L's Avatar
Lowering the compression ratio does nothing more than lower the overall efficiency of the motor. It just plain doesn't pump as well.
Keep the compression up and raise the boost.......then all you need is the octane to back it up
Dale
