Summit Linelock kit
Summit Linelock kit
I built my linelock kit last week ( just now getting the pics up) out of a Summit Racing kit.
I had to fabricate my own mounting bracket, bend the one of the lines that came in the kit and change out one fitting but it turned out nice and the price was right!!! ($107 including shipping....$71 for the solenoid and wiring and $27 for the line and fittings kit)
I like Tommy's kit, but I enjoy building my own stuff (not to mention short on money the past few weeks) so here are the pics.
Here is another picture with the motor out, you can se the LL lines (this picture was added to this thread much later than the original post)
You hold on the brake pedal, and then hit a button, which "locks the line" on the front brake. It makes it much easier to do a burnout, since the front brakes are locked, but the rear brakes are not. It's basically a solenoid in series with the front brakes. In normal use, it doesn't do anything.
Hope that helps
Hope that helps
Originally posted by JeffsLightning
Where did you mount your switch and indicator light? Thanks
I have the switch in the upper console where the sunglass holder is. Just flip down the door and hold the button
I will try to remember and get a pic of the switch for ya'
(((UPDATE: I eventually moved the button to underneath the steering column and prefer it there....much easier access....and almost as stealthy
