Question about JDM chip...
Old Oct 12, 2003 | 01:01 PM
fractaldragon's Avatar
I had the thing running fine until last night I went to the track and took the chip out to run stock. Truck hasn't started with chip since. My PCM is so clean I can eat off of it! (I have cleaned these before).
My chip wants to "wobble" on the PCM ie loose. Anyone else with a JDM chip experiencing this?
Old Oct 12, 2003 | 01:28 PM
Certified Drunk's Avatar
Pull the computer away (1/2 inch) from the bracket than try reinstaling the chip. It sounds like the chip is hitting the bracket, you might need to flatten the bracket by where the chip go in.
Disconnect the battery for a few minutes.
Old Oct 12, 2003 | 01:36 PM
hdmlnium's Avatar
Thumbs up
Sounds like good advise to me..
Bill
Old Oct 12, 2003 | 01:38 PM
LatemodelRacer2's Avatar
IF you say the chip is moving around do you have it taped in there
Old Oct 12, 2003 | 01:41 PM
Flatten the PCM bracket around the hole where the chip sits?
I have my keys out of the ignition, then unhook neg. terminal, unhook PCM, pull box, install chip, tape it down, reinstall PCM, rehook battery, then turn ignition on and let the gauges max and come back down and then try to start it....right?
Old Oct 12, 2003 | 05:12 PM
I took the bracket out (PITA!) and flattened the top 2/3's with a hammer and carefully taped it and reinstalled it and it worked!
Thanks for the input...I never had to do that with my 2000 ???
Old Oct 12, 2003 | 05:35 PM
the bracket is a BIA but having a chip makes up for it.
Old Oct 12, 2003 | 08:11 PM
promodlightning's Avatar
Thanks for the reminder...
Old Oct 12, 2003 | 08:18 PM
LightningCT's Avatar
I have a JDM chip (installed two weeks ago). No problems here....but here's the installation directions from JDM if you don't have them....did you snip the bracket and then bend it back to allow the chip to sit flat on the PCM??
http://www.teamjdm.com/id77.htm
Old Oct 12, 2003 | 08:57 PM
This is not my first chip install. It worked fine until I took it out once last night. I took the bracket out of the truck and hammered 2/3's of the edges flat leaving the bottom curved (below the chip). The little bit at the bottom still gives the box support.
