diablo chip installed, not starting
Old Oct 9, 2003 | 10:57 AM
halflife's Avatar
Installed the Diable chip with 2 programs last night. After installing it the truck would only start in the stock setting. I tried several times to start it in program one and 2 but it would not turn over. I started it in stock then flipped it over and ran the truck. Now it starts in all modes after driving around for a while. Just wanted to make sure that I did not screw anything up.
Also, can I just flip from one program to another while the car is running or do I have to restart it?
Thanks for the help.
Old Oct 9, 2003 | 11:07 AM
Dan_03Lightning's Avatar
Yes, you can switch from one program to the other while on the fly, but if you want to switch to the stock setting you need to turn your L off, flip it to stock setting then turn your L back on for stock settings to operate.
When you turn your L off, and then switch to one of the other two programs (other than stock) does it start ?
D-Day
