Don's Bolt gets smoked
You might have to do a little street racing to get used to the clutch. Maybe start hanging out with some ricers or something and get one of those BIG-*** tachs w/ a shift light.
We want video!!!!
Sounds like you guys had fun.
Jeff
It should be a pretty flat surface at the line, so you shouldn't need your brake at all. Just hold in the clutch and keep the rpms at about 3k. When you launch....let out the clutch smoothly and slowly increase the throttle or moderate the throttle to keep wheelspin at a minimum. A good launch should squeek the tires, but not spin them. Good luck...I'm sure you can get a low 15 out of the Focus.
Car-Stats.com Report for 2003 Ford SVT Focus
Obtained from C&D May, 2003
0-60: 7.7 Transmission: Manual
1/4 Mile: 15.9
1/4 Speed: 89
Originally posted by fractaldragon
Ummm....not gonna happen in a stock SVT Focus...they run mid 15's to high 16'swith a decent driver...
1/4 Mile: 15.9
1/4 Speed: 89
1/4 Mile: 15.9
1/4 Speed: 89
Don,
If you want a rematch, I will be there tomorrow night.
This is your chance to make it right..
How often does this happen????
See you Friday night under the Lights..
Bill
Bill
How about the lightning front end on a Windstar?
