Alignment HELP?
Old Oct 6, 2003 | 11:27 AM
Silver 2002's Avatar
Alignment HELP?
I have a 2002 Ford Lightning and I think I am having an alignment problem. My right front tire is worn on the inside part of the tire, Is this due to bad alignment?? I have had it aligned and I have had the tires balanced several times but I still have a shake at 60-70mph and a pulling. Is aligning a Lightning different than a regular F-150? Please help I am really getting frustrated with this problem.
Old Oct 6, 2003 | 12:26 PM
93Cobra's Avatar
Do a search for "alignment spec's" here - they are Lightning specific. You could be loosing the front end alignment if your lower control arms are moving. Also, a NAPA cam bolt kit more than likey will be needed to adjust correctly. Why they don't come that way from the factory, I will never know.
