service Q ?
Old Oct 5, 2003 | 12:48 PM
Dean Phillips's Avatar
Question service Q ?
Stage 1, 4lb lower, 2 stage chip for 95 octane, shift kit, boost bypass, cold air intake and sparks all from JDM should be with me by the end of the week. Plan the install and dyno before and after numbers, should be interesting with the cool temps in the UK at this time of year. Truck is up to 3000 miles now and I`m wondering what mileage to carry out a full service. I`ve looked in the manual but wonder if it would be better to do it sooner.
Have used Mobil 1 on other cars, should I put more miles on before using this or is it ok now. Also it calls for 5w 20 oil, but will it be safe with 5w 30, as I already have some of this in stock. I`ve looked and have only seen this rating in stores, so I would have to order in special 5w 20.
Trucks running real well and never stops making me smile when you hit the loud pedal !
Old Oct 5, 2003 | 12:56 PM
litnfast's Avatar
I switched over to Mobil 1 at around 4,700 miles with no problem. You better order a couple new F-1's now. Your going to need them soon when you put those new mods on Good luck...
ooops... Mobil 1 5-30 is what I use
