KB With a 3" Upper-Can't Wait
Originally posted by casper lightning
anyone running stock rods, if so how much boost are you pushing?
I'm running a JLP single program chip and a 2# lower with a 3" upper. We have the shift points set at 5200rpm to help alleviate some of the stress on the rods. I see right at 16psi at the 1-2 and 2-3 shift, then she settles down to 15psi in 3rd going through the traps at 5000rpm. We'll be installing a set of Long Tubes this week in an effort to help further alleviate cylinder pressure, and I'm sending my chip back to JL to be converted to a flip.
IMHO, this is the MOST boost I'd run on a stock block.
Furthermore, I will NOT take my truck above 5100rpm in 3rd gear on the street, and ABSOLUTELY keep away from ANY kind of SUSTAINED top end runs. It's a TRUCK, it has all the aerodynamic efficiency of your average brick wall. What's the point?(at least with a stock motor.) Just my .02.
Hope this helps,
Rob
BTW...going from a 3.25" upper to a 3" upper will most definitely bring a SMILE to your face
Originally posted by easterisland
If if get good traction my mph goes down compared to runs when I don't get good traction and my 60 foot times are slower...
That would seem to make sense, but it doesn't work like that for some reason. I'm sure someone on here could explain why.
Take the same vehicle at the track on the same day making the same power.
When you improve your 60' time, the vehicle has less time to make mph over a given distance (1/4mi. in this case). So, by hooking up better, you effectively lower your ET, but generally won't notice a big difference either way in trap speed, cause the motor's still making the same HP. There are obvious exceptions to the rule, but I believe this is a good rule of thumb. Just my .02.
Later,
Rob
