Track tonight!!!
Old Oct 2, 2003 | 09:46 AM
red99svt's Avatar
4#pulley
Ok im going to the track tonight to run my stock lightning..I want to run it stock before i slap on my 4# pulley that should be here today.Hey im going to this club wars this saturday in orlando and want to run the 4# pulley what other mods do i need to run this pulley w/o blowing it up?? I have a airaid intake on the way but it wont be here before saturday. What can i do??can i just run the 4# puley w/o other mods or is that a bad idea?? thanks
Old Oct 2, 2003 | 09:48 AM
moses Black 01''s Avatar
Definantly get a chip to match it. To be safe
Old Oct 2, 2003 | 02:04 PM
red99svt's Avatar
chip
Alot of people say not to get a chip unless u go over 6# pulley of boost.
Old Oct 2, 2003 | 02:26 PM
Rob_02Lightning's Avatar
Many run 4lb pulleys wo chips
HOWEVER
my famous line is -->WHY WOULD YOU WAN'T TO ???
A chip is the L's single most performance giving Mod we have
availble to us. With a Chip Filter + Pulley, your looking at 35-50 HP. Plus you get to dump that horrible Rev Limiter, change you shift points to where they belong, shut off the Torque Reduction,
Add Timing and Power, correct the A/F for optimal performance
with the Pulley, and much more .....
So to answer you question, ya you can do it,
but you truly should be changing the plugs and chipping it
if you want safety and optimal performance from that pulley
Old Oct 2, 2003 | 03:36 PM
red99svt's Avatar
chip
So just bolting on the pulley isnt a good idea then huh???
Old Oct 2, 2003 | 05:20 PM
Konig's Avatar
Im not running any of my chips right now, I have my 2#er on with no problems at all....havent had a chip on for about 2-3 months now. If your going to do a 4#er I would change out the plugs. I bought a set of NGK TR-6 plugs recently, Im going to put them in when I hit the Bradenton track in november sometime...I will be adding a 2# upper, or changing to a 4# lower by then.
You should come out and race with us sometime, being your local and all....
Old Oct 2, 2003 | 05:56 PM
red99svt's Avatar
race
Well i would if i knew were u guys hang out and all. Im a member of the club badrap.. i usually hang out with them on saturday night s at sonics on gandy..
Old Oct 2, 2003 | 06:22 PM
BigFan's Avatar
A Chip is not needed to run a pulley, I ran my truck 02 Lightning for 15,000 miles with a 6lb pulley and no chip. I ran it in temps ranging from -25 degrees to 110 degrees. I never had detonation and never even changed my stock plugs. I checked my timing with a Ford Scan Tool, my timing was at 12 degrees and a/f ratios on the dyno were around 12.4. It wasnt until just a few weeks ago that I got a reflashed computer, I have since dyno'd as well as monitor timing with the same Ford Scan tool. Guess what ? My reflash has a more agressive program than the stock tune had. My timing is now at 17 degrees and A/F was lowered to 12:1. My truck dyno'd at 405/520, a chip will enhance your performance but it is not needed when adding a pulley. Do a search on NLOC, there is a post where at least 20 guys say they run a pulley and no chip. Some had detonation with chips, when they pulled the chip the trucks had no detonation. Do what you want becuase its your truck but do be fooled by all the people screaming that you will blow up without a chip.
Old Oct 2, 2003 | 06:24 PM
Konig's Avatar
I was gonna go to that show last week I think it was, or maybe the week before...but it rained so I said screw it.
Me and George usually go to the Ronnie Setser show off Dale Mabry and Flecher...its in the mission bell plaza by checkers.
As far as racing goes... I usually like going on thursday nights during winter, sometimes saturday morning is nice. Every now and again they have the "Club Street Racing" thing going on there... the tree goes from red directly to green, and there are lots of imports and HS kids to embarass themselves...its fun all in all
George usually posts when he is going on the FLA site...
