So close
Old Oct 2, 2003 | 08:19 AM
Don's Bolt's Avatar
Red face So close
Went to the track last night to try out the new fuel injectors and mass air, the same one svtf150 has.
If only I could have gotten some traction, I either spun off the line or if I got traction , spun in the middle of the track.
I got 3 runs in the 11.0's
ended up with a best of 11.023 at 125mph
I will try this weekend when they prep the track
wish me luck, I only need 3/100th of a second
Old Oct 2, 2003 | 08:21 AM
swiseuf's Avatar
good luck, but geez its hard to feel bad for you when youre running 11.0's!!!!!!
Old Oct 2, 2003 | 08:23 AM
ShaneMcKenna203's Avatar
good luck man
shane
Old Oct 2, 2003 | 08:26 AM
Dan_03Lightning's Avatar
I smell 10's!
D-Day
Old Oct 2, 2003 | 08:28 AM
therealgeronimo's Avatar
Old Oct 2, 2003 | 08:30 AM
LIGHTNINROD's Avatar
Track prep=traction=10s for Don !
Dan
Old Oct 2, 2003 | 08:32 AM
LatemodelRacer2's Avatar
10's babby
Old Oct 2, 2003 | 08:49 AM
MaxPower's Avatar
God, I wonder what an 11.0 run feels like? Must go by like a blur!!
You're knocking on the door of those 10's!!! WTG!
Old Oct 2, 2003 | 08:58 AM
99svtlightning's Avatar
Good luck, at 125mph you should see a 10 easy if you hook up. I'm may give it a shot this weekend also, I just need to buy some 30" slicks again. My 28's just aren't doing the job like I had hoped.
Old Oct 2, 2003 | 09:11 AM
Ayrton's Avatar
Hell yeah...
Old Oct 2, 2003 | 09:21 AM
casper lightning's Avatar
what size injectors, and mass air are you using?
Old Oct 2, 2003 | 09:31 AM
Quick_Pick-up's Avatar
don't join the "jump club" and you're there Dude
Pauly G.
Old Oct 2, 2003 | 09:35 AM
NTIMD8's Avatar
I feel slow all of a sudden
Old Oct 2, 2003 | 09:54 AM
What is the difference between a 28" and a 30" slick? Thanks, shane
Old Oct 2, 2003 | 10:20 AM
jarmstro's Avatar
2 inches.... (J/K)
Depending on the rear gear a shorter tire would give you a lower gear ratio and a taller tire a higher gear ratio.
