PCV - Revisited (oil in intake)
I have decided to stop messing around with all the various methods of contolling the oil in the intake situation and completely get rid of the PVC system altogether.
I would like to leave as much of it there as possible so I can reconnect it easily when I have to go through DEQ testing.
So I have a question for those who have done it, such as EasterIsland.
1) On the passenger side.... Can I just put a Vacume cap on the PVC valve and plug the line where the hose plugs onto the PVC valve ? ..... and just leave all the rest of the stuff connected ? (I do have the breather cap at the oil fill location)
2) On the driver side..... I was just going to plug the PVC hose and install a breather on the valve cover.
Re: PCV - Revisited (oil in intake)
Promod,
Ok, so you say you vented some serious oil out your breather and onto your exhaust......... (glad you didn't catch on fire)
So in other words....it sounds like there is plenty of oil from that side that is capable of making it into your intake ?
Perhaps I will still install a breather on the driver side but use some 5/8 hose and mount the breather a little ways up and away, instead of right on the valve cover.....
You think that might help ?
Promod,
Promod,
Dirtchicken,
I know Easter has no EGR system, but I could have swore I have seen threads where he has said he removed the PCV system also.
Maybe it is time I Start a new thread with Easters name in the title so he is sure to read it.
Also.... Promod..... where you still running the stock pvc on the passenger side when you tried to run the breather setup on the driver side ? If so..... that might be why you were spewing oil out the driver side breather..... as the stock PCV valve never completely closes.....
The Swanson Kit really works.
I posted this thread with a pic back in July. My intake is still dry.
https://www.f150online.com/forums/sh...hreadid=121676
