collapsed filter?
Old Sep 25, 2003 | 01:22 AM
400HPHD's Avatar
collapsed filter?
Went to Ford to day to check on the status of my truck and the tech pulled me aside and said "take a look at your filter(12")"....Well it was collapsed. Look like someone squeezed it. Now my question is.....Did it collapse from the JLP box,Pro-Glass cowl hood and ram-air set up? Or is it not getting enough air? I have a JLP outerwear filter on it so I didnt notice it until today. And....If it collapsed doed that mean I am losing HP's? And do I need a bigger MAF?
Old Sep 25, 2003 | 06:40 AM
Rob_02Lightning's Avatar
400HPHD
I run as high as 14-15 lbs of boost, Johnny's box, and ram air without ever having a prob. The only collapsed filter Prob's I've seen where from aftermarket S/C's sucking in tremendous amounts of air, even to the point, they colapse the filter.
I know of many using that hood without prob's too
Whats you Mod List look like ?
Old Sep 25, 2003 | 12:46 PM
400HPHD's Avatar
Rob02.
10# lower
2.70 upper
JLP box
ported plenum
SB throttle body
JDM spacer
metco idler
ported Eaton
dynatech LT"s
no cats
bassanio catback
SMC alky injection
100 shot nitrous(wet)
ruslow underdrive pulleys
Kenne bell boost a spark and boost a pump
denso IT-22's
e-fan and e-pump
JDM heat exchanger
Carbon fiber driveshaft
4:10 gears
JLP trac bars
JLP d/s loop(2)
JLP breather
PSP nitrous plate
90mm MAF.....
Old Sep 25, 2003 | 12:49 PM
01Lightning's Avatar
Holy Sheeott!
Old Sep 25, 2003 | 12:53 PM
400HPHD's Avatar
I need to update my name on here....Last dyno when we discovered the filter idea....was 528@679...NO nitrous....!!!!
We were spraying last year with a 100 shot and got 632@729...Truck is under surgery right now getting 03 heads fixed UNDER WARRANTY from Ford!!!!! Very mod friendly dealer!
Old Sep 25, 2003 | 12:58 PM
Are you running a stock bottom end? Awsome number BTW
Old Sep 25, 2003 | 01:01 PM
TSDuke's Avatar
Hey now, don't forget the Manley rods!! Don't give those guys without them any ideas that they can run what you do without throwing one through the block.
Old Sep 25, 2003 | 01:18 PM
400HPHD's Avatar
Oh yeah...thanks TS....!!! Manley rods provided by Sal...!
Old Sep 25, 2003 | 03:14 PM
99svtlightning's Avatar
Nice list of mods....I did have a filter collapse on me once, but the metal edge down the filter was already slightly bent. I was running 18psi at the time. 20psi and no problems yet, so it may have been a weak filter.
Old Sep 25, 2003 | 03:25 PM
mecca's Avatar
Wow. Putting down these numbers on the stock eaton? Thats amazing! No head work, no cams? Nothing? Thats where I want to go. I want to run the stock eaton real fast, and crank out amazing numbers like that on it.
-Mike
Old Sep 25, 2003 | 05:10 PM
400HPHD's Avatar
i am going to try a new filter....without the outerwear on it....My numbers are thanks to a good,good tune and the SMC kit really helps. The Eaton will be coming off soon and I will be trying the new MP blower in a couple weeks. Believe when I say, this Eaton is pumping out mad heat and the nitrous/alcohol really help to cool it down. Crower Stage 2 cams are on the workbench awaiting installation.
Old Sep 25, 2003 | 05:19 PM
Blown93's Avatar
What year is your truck...
PEacE............
JIm.
Old Sep 25, 2003 | 05:33 PM
400HPHD's Avatar
PEacE............
JIm.
'02
Old Sep 26, 2003 | 06:31 AM
Originally posted by 400HPHD
Rob02.
10# lower
2.70 upper
JLP box
ported plenum
SB throttle body
JDM spacer
metco idler
ported Eaton
dynatech LT"s
no cats
bassanio catback
SMC alky injection
denso IT-22's
e-fan and e-pump
JDM heat exchanger
4:10 gears
JLP trac bars
JLP d/s loop(2)
JLP breather
PSP nitrous plate
90mm MAF.....
Ya, id say that set up, is sucking in a tremendous amounts of air
alright.
Real nice setup 400HPHD,
AND AMAZING NUMBERS,
I got to believe someone makes a re-enforced filter for
an air sucking monsters like that ?
ANYONE KNOW OF ONE ???
Like I say I run the extra large filter, (don't have your Prob, BUT)
I think it would actually be pretty easy to fab some kind of a
Steel Wire frame that you can insert into it ?
Just a thought, if it happens again....
BTW
It's decided
Your my new God
Hi Boost, Big Nitrous HP, a man after my own heart.
