170* Thermostat information
Old Sep 24, 2003 | 03:23 PM
01Lightning's Avatar
I installed my 170* Stant thermostat yesterday. I used the handy multifunction odometer display to record before and after coolant temperature readings. The readings on the display are in deg celcius, but the numbers below have been converted to farenheit.
Stock thermostat: 190 - 194
170* Stant: 176 - 180
DIFFERENCE: -14 degrees
As indicated, both stats allow the same amount of variance (4*) but the 170* stat holds the actual temperature much closer to it's advertised temp. Almost looks like the stock stat should have a rating closer to 190* instead of 180*.
I would also like to add that if you are goint to change your thermostat and plan to drain some coolant, make sure you drain the radiator and not the intercooler
Sammy
Old Sep 24, 2003 | 03:43 PM
Konig's Avatar
how complicated is it to use the odometer function?
Old Sep 24, 2003 | 03:47 PM
Just press and hold the odo button, crank your truck, and release the button when the diplay says "test". Press the button to scroll thru different readings. The coolant temp says "degC---" where the --- is replaced by the temp reading in celcuis.
Old Sep 24, 2003 | 04:16 PM
LTNBOLT's Avatar
Cool
Here are the results from heating the stats in water slowly.
Starts Opening
172 (160 stat)
190 (180 stat)(stock)
Wide Open
178 (160 stat)
200 (180 stat)(stock)
Old Sep 24, 2003 | 04:35 PM
Konig's Avatar
thanks, ill give that a try. Im installing a 160 stat soon here.
Old Sep 24, 2003 | 05:39 PM
ShaneMcKenna203's Avatar
LTNBOLT thanks for the #'s
Shane
