Noisy spout on KB
Old Sep 21, 2003 | 08:42 AM
B4THNDR's Avatar
Noisy spout on KB
The noise from the front spout of my KB sounds like a thrashing machine at idle. I called KB and they said it was normal, especially with a rough idle(cams). It does seem to quite down some with some rpm's. I just wondered how many of you guys with the KB's are experiencing the same thing????
Mike
Old Sep 21, 2003 | 08:50 AM
Don's Bolt's Avatar
Thats BS
My first KB was like that
KB sent me a new unit and it is as quiett as the stock blower.
I have a set of Crower cams so tell them to send you a new blower.
Old Sep 21, 2003 | 08:57 AM
KB ZILLA's Avatar
I agree with Don, tell them to send you a new one.
I dont have aftermarket cams, but mine is quiet
Old Sep 21, 2003 | 09:13 AM
owheelies's Avatar
Mike,
Aren't you on your 2nd KB already? I thought it was you I was talking to at Gainesville that had one seize up.
Eric
Ps. You heading to Lightningfest?
Old Sep 21, 2003 | 09:23 AM
easterisland's Avatar
It seems as is mine is getting noisier with time. It has around 18K miles.
Old Sep 21, 2003 | 11:16 AM
Twinturbo Ranger's Avatar
Mine is noisy at idle, but is quiet at any other rpm. I think it may have to do with the blower rpm at idle, but I can't really prove it. When I first put the blower on I ran a 3.5 pulley with a 4lb lower pulley(not sure of size) and it was quiet. I then upped the lower to a 6 lb(9 inch) and the noise started. I now have a 2 3/4 upper with the 9 inch lower and it has gotten quieter again. I was told it was gear lash?? I'd be interested in knowing what you find out.
Thanks Mike
Old Sep 21, 2003 | 08:53 PM
B4THNDR's Avatar
Don,
Send me an email so I can email you back.
Mike
Old Sep 21, 2003 | 08:54 PM
B4THNDR's Avatar
Don,
mmeyers@innet.com
Mike
Old Sep 21, 2003 | 08:56 PM
99svtlightning's Avatar
If the idle is low, like 650 or so, and you have a lumpy cam they will make that noise. If you raise the rpm slightly it will go away.
Old Sep 24, 2003 | 05:44 PM
Dan_03Lightning's Avatar
No unusal noise from mine, mind you I only have 500 miles on her. I am running a 3.20 upstairs and a 9.25 downstairs. Stock lower, cams etc.
D-Day
