Injectors/Pumps or both at 500+?
Old Sep 24, 2003 | 02:53 PM
Dan_03Lightning's Avatar
Mike,
I am running a 3.20 on top and 9.25 bottom. I actually saw 17lbs of boost before I put on the long tubes, high flow cats and Magna flow - but I lost a lb due to the better flow (I believe) - at least it is more efficient.
I still have a stock bottom, so I am a little nervious going into the 500+ range, but my tuner said with my current set up and the new injectors I could count on 530 hp range.
Personally, with the Nitto 555R's I have been able to almost master my launches - I wonder if an extra 40 hp is going to be more of problem on launch or more of a benefit. You know, at what point do our L's become really difficult to launch regarding hp levels??? (on the street)
I certainly wish you success with the new injectors and will be curious as to your results!
D-Day
Old Sep 24, 2003 | 02:58 PM
saleensc's Avatar
Originally posted by Dan_03Lightning
I did the two 255 cobra pumps and maxed my injectors at 496 hp, but not to mislead. I was pumping out 16lbs of boost from my KB.
My tuner told me to either keep the boost and buy the injectors or reduce the boost to see the 500+.
D-Day
Good Luck
Just curious, but is Justin at J&J doing your testing?
Old Sep 24, 2003 | 03:15 PM
saleensc,
No, I decided to head across the alley to REM in Margate. REM did most of my part installs and I started with a tune there, but ended up in a group Lightning tune in Miami with Willie Figueroa (Performance Tuner for Diablo) - in my opinion he is awesome!
Locally I have found another performance shop I trust, Mustang Motorsports the owner (and sole mechanic) is Chris Olmo - very trustworthy and he works with Willie.
If you want any numbers let me know.
D-Day
Old Sep 24, 2003 | 03:24 PM
saleensc's Avatar
Actually I'm heading to J&J right know to do my base run. I am close friends with Justin. I have met Chris as well. If you have one of his cards, That is an identical saleen to the one I just sold two weeks ago. I have a 99 that I have not made any changes to what-so-ever. As a matter of fact it was the first Gen 2 in Lee county. I ordered it 8 months prior to production from Bartow ford. Got it a full month ahead of them arriving at Langford and Galloway Ford. It was lonely around here for a while but I am seeing more and more. We'll have to get together. BTW, I was EATONPONIES when this board started if any of you old timers remember.
Old Sep 24, 2003 | 03:44 PM
saleensc
Sweet ride man, the SVTOA club meets every second Tuesday of the month at Galloway Ford in the service dept. 6:30-7:00. Let me know if you'll be there.
D-Day
Mike sorry for the Hi jack!
Old Sep 24, 2003 | 06:58 PM
Twinturbo Ranger's Avatar
So at this current time you have the stock pumps and injectors? I have long tubes and a full exhaust also. I have the blower pullied for around 18 right this second, with a single blade TB and extrude honed plenum. I could expect the WOT being a problem but I was not expecting part throttle problems at all.
Thanks Mike
Old Sep 25, 2003 | 03:43 PM
Mike
I actually have replaced the stock pumps and changed to two 255 lb high flow cobra pumps, but you're right I have the stock injectors.
That is very strange (from what I know) that you would be having problems outside of WOT.
I expect my L to get stronger as time passes. I only have 2000 miles on her and everyone has told me that our engines tend to show more power as they break in.
D-Day
