Cageless Pullleys
Old Sep 19, 2003 | 03:21 PM
Redlytnin's Avatar
Cageless Pullleys
Has anyone had any front main bearing troubles running a cageless lower pulley. The reason the cage was originally included was to help elimintate the chances of a problem.
Old Sep 19, 2003 | 03:39 PM
lurker's Avatar
One of the tuners broke a crank off near the front recently. Rumor was it was a cast crank but the requested pics never showed up...
Old Sep 19, 2003 | 05:25 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Re: Cageless Pullleys
The cage was included to eliminate chances of a problem?
Well, since the stock pulley weighs a fawking TON, the cage is necessary.
Cageless pulleys are very lightweight in comparison so to answer your statement/question. Not that I've seen, read, or heard about.
Bob
Old Sep 19, 2003 | 05:37 PM
retics4me's Avatar
whats nice about cageless pulleys is that they actually come off when you need them too
Old Sep 19, 2003 | 05:45 PM
LIGHTNINROD's Avatar
55,900 miles with a cage-less pulley on since the 4,000 mile mark--no problems !
Dan
Old Sep 19, 2003 | 06:33 PM
cpeapea's Avatar
one of the local tuners told me it can wear out the thrust bearings, but many people have been running these motors many miles without problems
Old Sep 19, 2003 | 06:38 PM
lightning5.4's Avatar
cage
I went with JDM's cage pulley it screws on like the stock one no three bolts to worry about coming loose just my 2 cents also eather one you use you may have some new blower belt noise at idle in gear with the AC on (belt flop) otherwise fine
Old Sep 19, 2003 | 09:28 PM
Tim Skelton's Avatar
deleted
Old Sep 20, 2003 | 03:14 AM
clonetek's Avatar
you know a really cool thing about the cage-less pulleys?
if your accessory belt was to ever break, you can replace it without removing the stock (or aftermarket caged) pulley!!!
