air box
Old Sep 15, 2003 | 02:18 PM
ramairboy98's Avatar
air box
anyone cut some holes on their stock air box? i cut 2 holes about half the size of my fist and it picked up some power/boost and the supercharger is louder now,sounds so sweet. does anyone have that procedure on how to bypass the boost drop in between shifts?
Old Sep 15, 2003 | 02:24 PM
cpeapea's Avatar
just unplug the boost bypass
Old Sep 15, 2003 | 02:27 PM
awhittle's Avatar
this should help
http://www.svtlightnings.com/svt/how...bypass_mod.htm
AW
0light1's Avatar
Welcome aboard!!
Opening the airbox up will net approx. 1# of boost. My tuner told me to just remove the bottom and wire tie a k&n to the top.
Pic here.
http://home.bellsouth.net/p/s/commun...eid=102679&ck=
It's not the prettiest but works very well. The whine is much
louder.
boost by-pass to keep from dropping boost is an easy one, unplug it. If you mean the 2-3 shift reduction bypass
You will need a chip.
-slo-poke
Old Sep 15, 2003 | 02:42 PM
just unplug it? how so? tell me i want more power,haha. any other free power adders,mine is stock except for xhaust and anda k-n,best so far is 13.20 at 103,will unplugging this boost damage anything?
Old Sep 15, 2003 | 07:51 PM
LIGHTNINROD's Avatar
I did a search for you. Readthis--all the way down and you will see a pic. Read what PSP/Sal says........ Mine has been disconnected for many miles--no problems.
Dan
Old Sep 15, 2003 | 08:11 PM
so if i do this bypass,will it make my s/c louder and how much can i expect to see off my 1/4 time?
Old Sep 15, 2003 | 09:04 PM
cpeapea's Avatar
it wont make anything louder, it will just not let it dump boost on the shift. read sals document it will explain everything
Old Sep 15, 2003 | 09:17 PM
bigdaddy's L's Avatar
Best photos are here
http://www.rpmoutlet.com/boost%20bypass.htm
