160 or 170 which one?
Old Sep 10, 2003 | 04:19 PM
ShaneMcKenna203's Avatar
Originally posted by HEVYRESQ
Just outside Chicago here....Ive got the 160*--only summer driven. So far, its working great for me
I live near Joliet also. I am off Caton Farm Road, HEVYRESQ where do you live? Thanks, Shane
Old Sep 10, 2003 | 04:41 PM
Casey02L's Avatar
Man; I feel out of place with my 170, but my temp guage always reads in the 160 range
Old Sep 10, 2003 | 04:45 PM
easterisland's Avatar
I'm currently using a 160° thermostat.
Old Sep 10, 2003 | 04:48 PM
Odin's Wrath's Avatar
That's strange. The temperature guage usually shows a higher temp. than what the thermostat is rated at. By about 10 degrees.... I believe.
Old Sep 10, 2003 | 04:56 PM
Patrick_PDX's Avatar
Oregon, summer driven 160 degree thermostat. Runs at exactly 75 degrees C. (167F) on the freeway according to the in dash diagnostic in the odometer.
If you drill about 3 - 3/16 holes in the housing of the thermostat it will keep the temperature more constant once it is warmed up. For example..... it will run exactly 75 C on the freeway instead of fluxuating from 75 to 78 while the thermostat is opening and closing. The only drawback is a longer initial warm up time.
Old Sep 10, 2003 | 05:05 PM
Dan_03Lightning's Avatar
BlownSVT, Jeff - you've got email.
D-Day
Old Sep 10, 2003 | 11:42 PM
Casey02L's Avatar
That's what I would think; but it is where it stays at when I am going down the road. Even with the AC on(I have an electric fan) But, I do notice that the TS seems to open up about 178~180 because just after that the temp drops back down when I am in traffic.
Old Sep 11, 2003 | 02:35 AM
promodlightning's Avatar
A 160 t-stat will operate in the 170s....a 170 t-stat will operate in the 180s...so on so forth.....my 160 usually stays around a 168 to 174 degree operating temp...
Old Sep 11, 2003 | 11:49 AM
Konig's Avatar
so where is the thermostat anyhow? Seems like a good cheap mod for me to do this weekend.
Old Sep 11, 2003 | 11:58 AM
tommylightning's Avatar
Follow the large black hose that comes from the top of the radiator and connects to the top of the motor. The neck that it connects to is where the thermostat is located. Hope this helps.
If a pic is needed, just ask.
Old Sep 11, 2003 | 12:02 PM
Konig's Avatar
I should be able to find it, if you have a pic that would be great all though.
Old Sep 11, 2003 | 01:31 PM
Cali L's Avatar
Do a search for "thermostat". There are great diagrams and how to's. I did this back in the day when I went with a "160"
BD
Old Sep 11, 2003 | 02:22 PM
Konig's Avatar
ill check it out
