How Much Boost Difference/
Old Sep 4, 2003 | 05:00 PM
tlfwatch's Avatar
Question How Much Boost Difference/
How much much boost difference should 8# pulley vereses 6#with chip. single blade throttle body already installed or should i even think of running an 8 #er or would it be better to change supercharger pulley and what size is next step up from stock???? All vendors should be uniform on size of pulleys although i have heard some wre selling some as 6# that were no more than 4#'s thanks
Old Sep 4, 2003 | 05:44 PM
easterisland's Avatar
1.2lb difference.
2.There is the chance your belt may slip more if you get a smaller upper pulley.
3.You want want to step down from stock. A step up would result in less boost.
4.In a perfect world all pullies would measure the same. However, it is not and all pullies, even some from the same vendor are different sizes.
Hope this helped you.
