102 Mass Air/Power tube by REM
If you guys have checked out my 112 install you noticed the new tube. The mass air sensor is in the tube so it's a nice clean design. They have a variety of colors so check them out (Red is my favorite)
Originally posted by Jubelands
Does the 102mm maf add any performance over the 90mm ones. I heard that anything over the 90MM was unnecessary
Anyone with a hair dryer blower ( Works & KB ) will easily spike the stock MAF in due time once they sort out their fuel requirements and raise the boost.
I believe there is a market for a larger MAF. However, i feel that new calibrated electronics need to go into the larger unit. Otherwise, youre just mimicing what C&L does with a large mouth and a different sample tube to match injector size.
That does look trick though
Pete, for all of us KB owners our KB warranty is out the window if we have an air flow system that only draws engine compartment air.
That's why I went with the JLP version, even though I really like the REM tube. If it (the filter) reaches the fender port then KB will accept it.
D-Day
D-Day
