Dynoed the JDM long block need input.
Old Aug 31, 2003 | 12:43 PM
L8 APEX's Avatar
This is supposed to be his best motor with cams, CNC heads, etc. I also port matched the upper intake and ran the following accessories. Acccufab TB, Fluidyne Xchanger, Cobra rotors and mild porting, long tube headers & Maganflow, electric fan, Art Carr 2000 stall triple plate, built trans etc.. After talking to Jim I expected to see 500rwhp and 600 rwtq. I have 1500 miles on the engine I made 447hp and 528 tq. I know there are a lot of these engines out there. Let me know if I am low or the 500/600 was high. I dynoed on a 6# lower making 13 lbs peak boost. I like the way it runs but am looking for a KB now! Thanks for your input!
idle clip
Dyno Graph
Old Aug 31, 2003 | 12:53 PM
easterisland's Avatar
That sounds nice for 13 psi.
I'm just trying to figure out the air fuel. It seems all these dynos I've been seeing lately are around the same #'s yours are. Is everyone is running 12 and higher now? Is it accepted that 12.0 is okay for WOT now?
Old Aug 31, 2003 | 01:03 PM
L8 APEX's Avatar
One of our guys has a 02 stock L with micro tuner and he runs 13.0 WOT.
Old Aug 31, 2003 | 01:09 PM
Grey03's Avatar
Real good numbers for only 13lbs of boost. I am sure the heads will make you even more power once you bump up the boost.
Why is everyone posting STD numbers recently, doesnt anyone want corrected numbers anymore?
UP FRONT
Old Aug 31, 2003 | 01:25 PM
soap's Avatar
STD is a correction factor...........
--Joe
Old Aug 31, 2003 | 02:18 PM
eatoncharged's Avatar
Banned
dude number one for all that, i would think you have some tunning issues to work out. number two, im not trying to be an *** but WTF is making that grinding knocking sound in the engine bay.
Old Aug 31, 2003 | 02:28 PM
cpeapea's Avatar
cams and longtubes
Old Aug 31, 2003 | 02:29 PM
L8 APEX's Avatar
That is the sound of power, LOl. j/k I think the blower has some wear it will cavitate or grumble occasionaly at idle. Rotor knock or gear mesh I reckon. The tune looks good flat a/f and nice curves.
Old Aug 31, 2003 | 02:39 PM
Banned
to me it just seems like you should be making more power than you did, but i dont know. maybe the eaton is at its limits at the moment. get one of the new magnum powers blowers.
Old Aug 31, 2003 | 02:58 PM
L8 APEX's Avatar
UP FRONT
STD is more accurate on forced induction apps in the summer. SAE was 6hp less yeaterday. SAE is more for naturally aspirated engines year round. SAE does not correct enough for instercooler efficiency and SC temps from summer to winter.
Old Aug 31, 2003 | 03:04 PM
RollinLimp2001's Avatar
Wow! I never knew that their cams lopped so much that you could see the movement at the exhaust tips
Old Aug 31, 2003 | 03:21 PM
Rob_02Lightning's Avatar
Nice numbers APEX,
and nice sounding idle and exhuast
Nothing like a little lift and duration to shake it up a bit
Your really not running that much boost when you think about it APEX, most of us run that boost level daily on a 100% stock block with no problems.
Schitt I juice mine on top of that boost.
I think it's time YOU STEP IT UP MY BROTHER
give that bad boy some more boost
BTW
Cavatation is very common for some, not a big deal.
mine sounds like a desiel sometimes.
But that still doesn't compare to the winter start ups.
You should hear it in a 20 degree winter morning,
it raps, taps, ticks, clunks, rattles, and rolls.
It's done that since day one, even when it was 100% Stock
and Brand New
IT RUNS GREAT, SO WHO CARES...........
Old Aug 31, 2003 | 03:31 PM
Grey03's Avatar
Originally posted by L8 APEX
STD is more accurate on forced induction apps in the summer. SAE was 6hp less yeaterday. SAE is more for naturally aspirated engines year round. SAE does not correct enough for instercooler and SC temps from summer to winter.
I understand what your saying about intercooler and S/C temps, but SAE factors in elevation, temp, baro and such so its a wash.
You have great numbers either way, so get that truck to the track and see what it can do.
ICE IS ONE OPTION
Old Aug 31, 2003 | 03:55 PM
L8 APEX's Avatar
My digi cam has a low frame rate you can barely see the tips move. I had to add two more hangers to arrest them. Like he said STD is a correction it does factor baro and temps etc. The motor has been very quiet no start up knocks internally. Jim said I had a newer version of pistons that fit tighter. I road race this truck that is why I keep the boost down. Stan (Ruslow) runs this motor and a 4# lower. Anything else would over heat or cause problems top ending for a while. Still nobody with numbers on their long block?
Old Aug 31, 2003 | 04:23 PM
Grey03's Avatar
You might want to read this. It will help you understand STD and SAE numbers.
SAE VS STD Corrections
GETTIN IN TROUBLE
