Ready for my QA1's, but which??
Old Aug 31, 2003 | 06:49 AM
JewishLightning's Avatar
Installed the "old" Hotckis TVS 1/2 drop and sway bars. Readjusted the sway bar links and now I need the shocks.
Do I get the TC-1538P for the front & TC-1610P for the rear, or get the MU-7855P for the rear? Do I need shock extenders? Or just the Heim kit? Fill me in!!!!
Neil
BTW Now that I have this kit, I have some of my old suspension that I'm ready to get rid of!!!
Old Aug 31, 2003 | 08:41 AM
owheelies's Avatar
You need to measure the length from t-bar to pocket in the front and bolt center to pocket in rear. These measurements can be used to determine which lenght shock is correct for you.
For the front:
TC-1538-P 10.25"-15.5" at ride height 13.4"= 60% compression
TC-1958-P 9.38"-14.38" at ride height 12.38"= 60% compression
For the rear:
TC-1610 14.5"-23.5" at ride height 19.9"= 60% compression
MU-7855 13"-20.5" at ride height 17.5"= 60% compression
QA-1 recommends the piston being 60% compressed at normal ride height. You also have to make sure the compressed distance will not bottom out the shock before you hit the bump stops.
Eric
Old Aug 31, 2003 | 05:44 PM
I guess i will have to hold off on the QA1's after my Works 112 that I just purchased!!!!! Busy week!!! Hotchkis, Carbon fiber 102 Mass air tube and 112. I got to lay low for one week from REM!!!!!
Tim & Paul shoudl make a REM Credit card!!!! With all I buy I can get miles on an airline!!!!!!!!
