will slicks improve my et's???
Old Aug 25, 2003 | 10:35 PM
Don's Bolt's Avatar
Originally posted by trashguy
can someone explain why goto 28 or even 30 "
tall slicks over the 26 " ,wouldnt the 26 " lower your gear
ratio and give better outta the hole performance?
You don't want to go with 30" slicks unless you are running a built motor and KB. The reason I run 30's is that with 28" slicks I was going through the traps at to high of a rpm.
The reason you want 28's over 26's is that they have a taller sidewall. The taller side wall will let the sidewall wrinkle and allow the slick to bite much better when you launch the truck.
If you could get a 26" to hook off the line, yes it would help lower the gear ratio in the first 300 feet or so, but it might hurt you in the top end. There is allways a trade off.
I don't know if you remember the post when JDM tried putting 4:11 in skinheads truck. They thought it might help, but it actually hurt the 1/4 mile time.
Old Aug 25, 2003 | 10:36 PM
C BROWN's Avatar
Well; All I get to run is 1/8th mile tracks, and getting off the line is everything. I have to admit that I have not mastered launching with the slicks to get my 60ft times down yet, but they are well worth it. Same night within 20 mins I went from a 1.87 60ft/8.15 1/8th to a 2.08 60ft/8.35 1/8th by going from my ET streets to stock F1's @28 pounds. That was leaving from idle, and flooring it off the line(I had to back out with the F1's due to spinning). These times were in 90 degree heat and a lot of humidity. Even if I can get off the line my truck has a bad problem about smoking the tires on the 1-2 shifts
My Mods:
02 L, JL lift bars, #4, REM chip, modded air box, FT valve body, underdrive pullies, and a few other small things. Oh, and my ET streets I just wish I had the stall converter you did, and I would be will into the 7's 1/8th.
Old Aug 25, 2003 | 10:38 PM
Don's Bolt's Avatar
If the track prep sucks nothing will help.
Edit
by the way I still have a set of Bogarts with 28x10-16 hoosier slicks for sale $750.00
Old Aug 25, 2003 | 10:39 PM
eatoncharged's Avatar
Banned
are traction bars a good idea even if you have stock tires?
Old Aug 25, 2003 | 10:42 PM
Don's Bolt's Avatar
Not really neaded with stock tires, but it is allways good insurance. Keeps the driveshaft in the propper allignement.
Old Aug 25, 2003 | 10:47 PM
Banned
hey don will those slicks fit a harley?
Old Aug 25, 2003 | 11:08 PM
C BROWN's Avatar
Edit
Wow; that's a good price. I almost spent that much for the setup I have, and I don't have Bogarts.
Something everyone should also remember about going to slicks; you will lose some weight. The stock wheels/tires are VERY heavy; going to any 16" with slicks will net you a nice weight savings, but Bogarts are super light.
Old Aug 25, 2003 | 11:11 PM
Don's Bolt's Avatar
Yes they will
Old Aug 25, 2003 | 11:19 PM
Banned
how many runs do they have on them, or should i say how many more would i get from them?
Old Aug 25, 2003 | 11:31 PM
Don's Bolt's Avatar
about 20 runs
should have plenty of runs left, I am basically seeling the rims and giving the tires away for free. The rims were $360 each, they might need to be polished up a little but they are billet so the clean up very easy. Yes they are real light.
I run the same rims now, just in 15" size
Old Aug 25, 2003 | 11:45 PM
blown318's Avatar
Yes they will
Old Aug 25, 2003 | 11:47 PM
SVT F15O's Avatar
Don if those rims were the 5-star design they would be sold!!!!! I love Bogarts but if I am gonna throw out that big chunk of change I am going for the star design. -Mat-
