will it fit?!?!?!
Old Aug 23, 2003 | 07:14 PM
Bryce_Thomason's Avatar
will it fit?!?!?!
have a 99 lightning and wondering if the 2003 L wheels will fit without modification to the wheel. anyone with first hand experience let me know thanks!!!
bryce
Old Aug 23, 2003 | 07:16 PM
eatoncharged's Avatar
Banned
theyll fit.
Old Aug 23, 2003 | 10:28 PM
ok cool just wanted to make sure
bryce
Old Aug 23, 2003 | 11:53 PM
SVT F15O's Avatar
Originally posted by eatoncharged
theyll fit.
It doesn't matter that the 99 has 12MM studs and the 03 wheels are made for 14MM studs>??? Just curious. I know our wheels are hubcentric but just want to be sure. Thanks, -Mat-
Old Aug 24, 2003 | 01:37 AM
that was my concern as well
Old Aug 24, 2003 | 02:16 AM
sporkdevil's Avatar
Fords change in 99 from 12-14 MM studs seem to be rather without any real clear implementation. Since I last checked this out, depending on the plant and such, some 99 models had 12MM studs and some had 14MM.
I guess the only way to really check is to measure the wheel stud and see from there. Or atleast buy 1 14MM lugnut and see if it fits. Whatever.
So the clear answer is this: The 2003 wheels may or may not fit a 99.
Old Aug 24, 2003 | 04:46 PM
swiseuf's Avatar
Im sure this has been covered here before- Are the 03 wheels the same size as 99-02?
Old Aug 24, 2003 | 04:47 PM
MISTERgadget's Avatar
the 03 wheels are 18"x9.5" just like every other year.
Old Aug 24, 2003 | 07:14 PM
has anyone actually changed them with sucess on an early 99?
Old Aug 24, 2003 | 07:41 PM
RDY2RAC's Avatar
well a friend put 03 wheels on his 12mm 99 L and has not had an issue just remember the torque for the 12 mm is less than the 14mm studs require. so dont over torque and stretch the threads. all lightnings are produced at ontario truck plant . yes some of the later 99's may in fact have 14mm studs but it would be because of a engineering change. if i'm not mistaking all 9.75 rears went to the 14mm studs after the 99 model year.
Old Aug 24, 2003 | 07:42 PM
Nathan's Avatar
I am currently using wheels on my '99 with the 14mm-spec holes. My lugs are only 12mm. The lighting wheel is a hub-centric design. The wheel hub bears all the accelerative force and the vehicle weight ... the lug nuts are there to hold the wheel on laterally.
Old Aug 24, 2003 | 07:52 PM
well thats good to know, just want to make sure before i go through with this
bryce
Old Aug 24, 2003 | 08:07 PM
LightningToGo's Avatar
will it fit?!?!?!
Is that what she said?
Old Aug 24, 2003 | 08:13 PM
Old Aug 24, 2003 | 11:14 PM
