L is sick
Old Aug 21, 2003 | 11:49 PM
therealgeronimo's Avatar
L is sick
When the L is in drive at a light idleing, it seems to sputter a little, the rms drop off from about 640 or so to 570 by the digital tach. Is it time to change my fuel filter? How would i go about trouble shooting?
Old Aug 21, 2003 | 11:52 PM
cpeapea's Avatar
did you try cleaning your iac?
Old Aug 21, 2003 | 11:54 PM
? iac ? is that in the airbox??
Old Aug 22, 2003 | 12:11 AM
SLVRNBLK's Avatar
Idle
Air
Control valve
Its the valve attached to the passenger side of your upper intake manifold ( I believe by 2 8 or 10 mm bolts). It tends to get dirty and clogged over time. Just disconnect the plug, remove the two bolts, being careful not to tear the gasket b/w the IAC and manifold, and clean it out. Takes less than ten minutes and is worth a shot. Good Luck
Old Aug 22, 2003 | 12:22 AM
I take it it can be cleaned with electrical contact cleaner?
Old Aug 22, 2003 | 12:25 AM
SLVRNBLK's Avatar
Carb cleaner should work fine.
Old Aug 22, 2003 | 03:56 AM
ttt
