How many have ordered the chip/pulley combo and it worked the first time?
Old Aug 19, 2003 | 09:17 PM
potac's Avatar
Did most of you who got this combo have to keep sending your chip back to get it tuned correctly.
More specifically. What are my chances of getting a good tune the first time I get the chip?
I would definitely get it dynoed after the install but I am wondering if I need to plan on sending in the chip multiple times. I want a very conservative tune that I can drive year-round and take long road trips (i.e. it needs to handle changes in elevation: sea-level --> 6000ft)
Mods would be 4 or 6 lb pulley, FTVB, S&B Powerstack, 91 octane in Cali, and Reno and 92 octane in Seattle (most of my time will be in Seattle).
Can I count on this setup to be a reliable cross country vehicle?
Thx
Old Aug 19, 2003 | 09:34 PM
Mr. Freeze's Avatar
Back when I had just a chip and pulley it worked fine the first time. It's usually when you ask for a really aggresive program that it needs tweaked.
Old Aug 19, 2003 | 11:15 PM
LatemodelRacer2's Avatar
mine has worked fine since day one
Old Aug 19, 2003 | 11:23 PM
RipNRun's Avatar
----Damned booze: edited for clarity---
I don't want to hijack the thread, but it seems that you could be a candidate for a PCM reflash.
I'd like to see more data on how well the reflash has worked after a winter and some significant mods, but assuming it works, it seems like a solid alternative for you if you don't want to continually reburn a chip.
--Rip
Old Aug 19, 2003 | 11:47 PM
Learo2000GT's Avatar
Hey Potlac..... you up for heading to bremerton in september for some cool temp runs... let me know.... Doug....
Old Aug 19, 2003 | 11:48 PM
SpankDog's Avatar
Banned
my combo works fine, its just too rich, im going to send back for a reburn and see if it can get better without an actual dyno tune
Old Aug 19, 2003 | 11:53 PM
ST.ELMO'SFIRE's Avatar
mine ran fine, but it ran better when JL dtatlogged it so i think it it always better to take it to your tuner to be right on, but they should be able to come close.
Old Aug 20, 2003 | 12:21 AM
potac's Avatar
I will probably go to Bremerton Sept 19th for street legals.
Tomorrow I am going to Pacific Raceways. I have not been for awhile since the weather has been a tad bit warm.
Old Aug 20, 2003 | 01:48 AM
promodlightning's Avatar
Mine too, when I had the stock motor....
Old Aug 20, 2003 | 03:47 AM
catchmario's Avatar
I have both a JDM Superchip and a JLP diablo chip w/
a 4# pulley and have not had any problems with it
from the beginning.
Old Aug 20, 2003 | 06:03 AM
Rob_02Lightning's Avatar
No two Lightning's will run the same on the same program.
Thats because our Beast's Performance is effected drastically by A/F, Timing, Climate + Octane used.
Potac,
Ask some L owners in your area what timing they're running
and have it set @ there. Keep it Super Rich, and run two zone cooler plugs and you'll be fine and trouble free as long as you don't WOT it 24/7
GOOD LUCK
BTW
Me, I'm a nut, (on my 10th Program in a little over a Year) BUT IT'S PERFECT NOW
Old Aug 20, 2003 | 07:40 AM
0light1's Avatar
My diablo worked fine the first time w\2# upper then when I added my 4# lower it worked good too. I have sent it back one other time to get a more aggressive tune (up the timing to 16deg). Very happy with all the tunes.
good luck
0light1
Old Aug 20, 2003 | 07:45 AM
2002Bolt's Avatar
reflash and pulley combo has worked great since it was installed. And i am very happy with these two.
Old Aug 20, 2003 | 11:13 AM
sorry to jack of this thread with cordinating meeting you in bremerton..... the 19th sounds good to me... email me at doug@osc-voc.com and we can cordinate a time to meet.
Doug
Old Aug 20, 2003 | 12:43 PM
LIGHTNINROD's Avatar
I have three different(tuners) chips for my 01 L. One has been 'spot-on', one is OK--fine, really, and one has had some issues....................
Dan
